07-06-2016, 02:31 PM | #1 |
Rep 3,056
Anyone have a pic of an Escort Max 360 mounted using Blendmount on F80
Thank you in advance for the pics, im about to pull the trigger on the blendmount with the mirror tap but i wanted to make sure it looks ok.
Fire Orange 6MT G80 (Miss July, 2021 Cover of Bimmerpost)
SMB M3 CS (gone) YMB F80 6MT (gone) |
07-06-2016, 08:09 PM | #4 |
Rep 268
I just bought the max 360 but haven't used it yet since my car is still in transit. Do you have any pics with it using the suction cup they give you? Have you used both and if so, which is better, blend mount or suction?
07-07-2016, 10:38 AM | #6 |
Rep 3,056
Which blend mount did you buy? The 007? Thanks for the photo, it confirms i made the right decision in buying a blendmount.
07-07-2016, 10:47 AM | #7 |
Rep 370
Yep, BMW-007. I also used a 15" MirrorTap .080" X .525" Large Tap to tap the Green/Brown (+12v switched) and the Brown/Black (ground) wires. The 15" is the perfect length.
07-07-2016, 01:08 PM | #8 |
Rep 3,056
I am completely inexperienced when it comes to handling this type of stuff. should i have a professional do it for me or was it that easy?
07-07-2016, 01:24 PM | #9 |
Rep 370
You can absolutely do it yourself. It only took me 45 minutes to install, and I adjusted the placement a few times. I recommend "lowering" the bracket a little bit from the stock height, it makes removing/refitting the detector a little easier.
07-07-2016, 01:26 PM | #10 |
Rep 370
Step 1: Split the black housing behind the mirror in half from center. Here is a picture of the inside so you can see where the clips are located. Be careful not to scratch anything.
07-07-2016, 01:32 PM | #11 |
Rep 370
Step 2: Push the Mirror Tap pins into the Green/Brown (+12v switched) and Brown/Black (ground) wires. Push firmly--you will feel them seat properly. Make sure you order the Large Tap (.080" X .525") or the pins won't be long enough to make contact.
At this point I turned the car on and plugged in the detector to make sure I had contact. I also zip-tied the Mirror Tap to the wire harness to make sure I didn't accidentally pull the pins out. |
07-07-2016, 02:05 PM | #12 |
Rep 3,056
suction cup mounted above the iDrive screen looks like crap. get a blend mount. great detector (although it hasnt saved me yet, ive been driving around brooklyn so theres no way to exceed 40 mph).
07-07-2016, 04:57 PM | #13 |
Rep 102
Drives: 2016 M6
Anyone else have an issue with the GPS signal coming and going? I assume it's cuz the mount and how close I have it to the rear view.
07-07-2016, 06:39 PM | #14 | |
Rep 370
08-16-2016, 04:56 PM | #16 |
Rep 88
TheElementalCashew69.00 |
08-16-2016, 05:13 PM | #17 |
Rep 370
08-17-2016, 09:05 AM | #18 | |
Rep 2,009
Suction cup is pretty damn strong. Lately with the temps here being pretty high it still hasnt fallen off due to the heat. It did fall off once but it was because I re-positioned it and dirt got on the gel adhesive. I just washed it and let it air dry and had no problems since. Zero performance issues with the location either |
