07-07-2016, 08:48 AM | #1 |
Advansolosis
218
Rep 1,448
ESS VT-2 625 Kit, What to watch out for?
Hi All,
Picking up my car from the shop tomorrow, they have just installed the ESS VT-2 625 kit on my car. The tune is a custom tune and not a ESS tune (since the reviews on the ESS tune is quite...sad). I've always been a large motor NA guy and never really ran FI. Anything I should watch out for on this kit? The last time I had a FI setup on my car was my old 535, which had a crappy fuel pump. Thanks in advans-ced.
2011 E90 M3, ESS VT2-650, 2015 GL550 |
07-07-2016, 10:03 AM | #2 |
Rep 999
Get use to the car before you take off traction control... It will spin for days with the kit
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
07-07-2016, 11:01 AM | #4 | |
Advansolosis
218
Rep 1,448
I also bought new tires for the M not that long ago. so I guess I should just order a new set lol
07-07-2016, 11:15 AM | #5 | |
Rep 661
2. Traction will become a major issue so you may want to look into a good set of performance tires and maybe an upgrade in overall size 3. Wheel hop becomes even more of an issue so you may want to look into getting sub-frame bushings. You may also want to invest in a set of diff bushing but with those, comes, additional NVH so educate yourself before going that route 4. I'd recommend a boost gauge (I like the P3 vent gauge from ACM) to ensure you're getting all those ponies you paid for. 5. There's going to be a lot of power especially over 5-6k rpm so get used to it before you go race mode. Last edited by 81bear; 07-07-2016 at 11:40 AM.. |
07-07-2016, 11:34 AM | #7 | |
Boosty
55
Rep 325
All that powaaaaa
'08 335i AT Alpina Flash~Rob Beck Turbos~Full kittyless exhaust~DCI~5" Intercooler~Chargepipe BOV~BMS meth kit
07-07-2016, 12:21 PM | #8 |
997.1TT
1010
Rep 1,672
A break in period to get your engine used to being boosted? Are you sure that the break in period isn't for the supercharger itself? I'm not sure a non living object knows whether it is supercharged or not or can possibly "get used to it"
07-07-2016, 12:26 PM | #9 | |
Advansolosis
218
Rep 1,448
07-07-2016, 02:40 PM | #10 | |
Rep 661
All I can say is I'm much happier with the day-to-day performance of my kit with my solid subframe/Diff bushings and 295 AD08R tires. |
07-07-2016, 03:21 PM | #11 |
Know's a guy that know's a guy...
5639
Rep 1,905
OP - Best preventative step you took was go with another tune...
Did you buy the kit new or used? S/C oil changes are tricky as the plugs will strip on you. I had to buy an easy out to get the vent plug out with the most recent oil change. I'd buy a couple extra plugs just in case. Also - I have a small hole in the bottom of the car's skid plate for the drain hose and tuck it out of view, and I have a small zip tie on the end of the drain hose that sticks out through the hole so I can pull the end of the drain hose through the hole easily. Change the air filter via the fender liner. Test Pipes, Wider back tires, diff and sub-frame bushings are your next mods |
07-07-2016, 07:57 PM | #13 |
Rep 1,376
I'm debating on doing the same where did you go if you don't mind me asking?
2018 F80 M3 ZCP Mineral White- Extended Shakir Orange - Full Suntek Ultra Wrapped - ///M Performance Spoiler - RKP Front Lip - RKP Side Skirts - Vorsteiner GTS Diffuser -AA Mid-Pipe-///M performance HAS kit - HRE P101
11 E90 M3 JEREZ BLK METALLIC ZCP SOLD |
07-07-2016, 08:30 PM | #14 |
Rep 1,682
If I remember, the ESS break in period is 500 miles and then change the blower oil. During that period all street driving is fine just don't go to the track.
07-07-2016, 08:30 PM | #15 | ||
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Why not be a rocket ship?
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
07-07-2016, 10:21 PM | #16 | |
Advansolosis
218
Rep 1,448
Motorcepts, I'm going to be there tomorrow to pick up the car!
07-17-2016, 09:52 AM | #17 |
Rep 1,376
How's the kit bro? Any vidz?
07-17-2016, 10:04 AM | #18 |
Advansolosis
218
Rep 1,448
The car is great! I stopped by Friday and it sounds amazing! I left the car there since they are working on some other stuff for me. Feel free to pop in there and take a look!
07-17-2016, 11:37 AM | #19 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Rear diff mounts are more important than the subframe bushings, especially if your manual trans. Suckers will snap rear diff bolts quick, also removes most of the wheel hop with solid rear diff mounts.
Break in period is for the SC blower, not the car engine.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
07-18-2016, 02:49 PM | #20 |
Rep 1,376
Wish I could bro I'm away on vacation maybe next time we can meet up
