07-07-2016, 10:44 AM | #1 |
Boosty
55
Rep 325
BPM emissions tune
I have the emissions tune file & I need to pass inspection.
There is test pipes welded on the car. I flashed to the emissions tune and the car was still not ready to pass emissions. I immediately flashed back to my sport tune. If I flash to the emissions tune & drive modestly for 50 miles & do a couple start stop cycles will that enable all the emissions to be "ready" for the inspection station?? Thanks
'08 335i AT Alpina Flash~Rob Beck Turbos~Full kittyless exhaust~DCI~5" Intercooler~Chargepipe BOV~BMS meth kit
07-07-2016, 03:29 PM | #3 | |
Rep 872
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
07-07-2016, 08:14 PM | #4 | |
Rep 616
You need access to a scanner that reads readiness monitors. Aside from advice from anyone, you need to actually scan your car to see what's ready and what is not ready. I do know that most emissions test stations do FREE checks. Might be worth looking into if you cant get hands on a scanner |
07-07-2016, 10:34 PM | #5 | |
I know a thing or 2 about a thing or 2...
3104
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
07-08-2016, 06:14 AM | #6 |
Rep 856
You still need to put your cats on. The emissions tune just enables the monitors so, with the cats, the system will run and complete its tests..
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
07-08-2016, 08:45 AM | #7 |
Rep 356
I use a $13 Scanner to check for monitor readiness and it works great. I was able to get most sensors to set with only 5-6 miles of slow (50-55MPH) highway driving on the West Side Highway except for Secondary Air which required a completely cold start with a short idle period.
I tried to PM the OP but your mailbox was full so send me a message when you have a chance. |
07-08-2016, 11:17 AM | #8 |
Boosty
55
Rep 325
Would the 02 spacers or SIMULATORS work? I don't have the factory cats ?
07-08-2016, 01:46 PM | #9 |
Rep 616
