07-12-2016, 08:43 AM | #1 |
Rep 8
Drives: 2016 M4 YMB
Brand new M4 - Front end of Car Sensor errors?
Not sure how to have better labeled this thread.. Anyways..:
Went to leave work yesterday, turn on car and was greeted with three-four warnings: 1) Front Cameras failure 2) Lane Departure sensor failure 3) Collision Warning sensor failure 4) Pedestrian Avoidance sensor failure Turned off the car waited a minute and turned back on and same message. A little worried I called to make an appointment with BMW. About 10-15 minutes later while driving.. All sensor errors went away and everything started working fine. Last three drives since last night have had no issue. But I did notice on the screen what seems to be the cellular/nav signal icon just flashing, not sure if that is something else but I have no errors or warnings on car today. Not sure what would cause this and if it's a warning of what's to come.. but it was 102 degrees yesterday (Central Florida) and it's strange that it went off by itself. Anyone experience this or have ideas? Thanks, mike
///M4 2016 YMB | Full Black Leather | 19" Black | Executive Pkg. | Lighting Pkg. | Carbon Fiber Pkg.
07-16-2016, 01:59 PM | #2 |
Rep 269
Yep. I get the exact same errors about every other time I drive. I took it in for service and they said they "there was no repair instruction". They updated the software as a remedy and now... it still happens almost daily. Highly frustrating. Let me know if you or anyone else can shed some light on this one.
07-19-2016, 12:45 PM | #3 |
Rep 269
I've heard the same. The problem is that it's hot every day in LA. In practical terms, this means the sensors fail daily. If it takes this little heat to cause a malfunction they've got a bad system. Needs a higher a heat tolerance than being parked in the sun for a few hours.
07-19-2016, 06:22 PM | #4 | |
Rep 3,945
Drives: 2015 M4 MG/SO
Thus said, sensors can intermittently fail... If any of you have rheingold check what faults are registered as many dealers skip over them and don't do much with it. |
07-20-2016, 08:39 PM | #5 |
Rep 8
Drives: 2016 M4 YMB
UPDATE:
I dropped off the car this morning as they wanted it all day and overnight to do software upgrade... SA mentioned that usually fixes this problem. SA called this afternoon and explained that there was a high temp reading in memory and it's known to be caused by direct sunlight/high temps and happens when parked in direct sunlight for extended periods of time. This aligns with the day it happened. I parked in a spot that the front of the car was in direct sunlight all day. I never park in that spot or direction and that was the only time it has done this. SA ended up keeping car over night to program anyways as I also have a strange bluetooth problem (or iphone connected problem) where the phone interface pops up randomly and it acts like its in a call (although it is not..) and I can't hang up or get it to release the bluetooth connection without turning off BT on my iPhone 6s. mike
07-21-2016, 01:35 AM | #6 |
Rep 269
It doesn't matter what they designed the car for - it only matters how it performs on a day-to-day basis. If the sensors have failed, that's not a big deal either, but only as long as they acknowledge it, take responsibility and fix it. Not the case so far. It's possible that if I continue to push hard enough and yell loud enough they'll step up and handle it.
Sadly, parking your car in the sun for a few hours is a daily occurrence in a city like LA. It's totally normal behavior. Most don't have the luxury of covered parking every where they go. BMW needs to either 1. Create a system that can withstand being parked in the sun or 2. Be willing to warranty it and accept responsibility if it can't. |
07-21-2016, 02:18 AM | #7 |
@ste4lthedF82
882
Rep 1,498
Drives: 2016 M4 SSII
Ive had the same issue many times. Live in L.A. and this happens during heatwaves and when car faces the sun directly. The issue is with the sensor camera that is behind the rear view mirror. Extreme heat and direct sunlight causes errors. I get frontal collision and pedestrian errors all the time after the car is parked in hot bright weathers. I believe this is a known issue. But resets back to normal each time.
Fyi... I brought mine to SA and even got a replacement rear view mirror camera. Stil the same. Good news is it goes back to normal.
2016 Satin SSII M4 (Instagram: @Ste4lthedF82)
see my featured mods below... http://f80.bimmerpost.com/forums/sho....php?t=1197842 |
