Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > AUSTRALIA
      07-13-2016, 10:02 PM   #1
simpelton
Australia
33
Drives: F80 M3
Scratched Wheel/Lug Nuts
I am padantic about apperance and visible damage and so have gone as far as vinyl wrapping the whole car and glad that i did - been pelted on a number of country roads now. Anyway took the car in for a service and mentioned that a stone caught on the ceramic caliper has scoured the inside of the wheel so they said they'd look at it.
Anyway pick up the car, have a quick look at the rims and no damage and check the ceramic rotors not damaged -just checked the front left as its the one with the stone scour and i assumed the only wheel removed.
Get home and thought id check the others to make sure no damage to the other rotors ( in case they removed all wheels and being safety conscious with the ceramic rotors). No damage look good but i notice that all the lug or wheel nuts are scratched. They are painted black ( factory oem ) and were flawless before i took it in. Rims are all clean.
Is this unavoidable with the nuts or have they been careless?
      07-13-2016, 10:08 PM   #2
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
I think the word is "pedantic" and doesn't mean what you think it does.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      07-14-2016, 02:18 AM   #3
simpelton
Australia
33
Drives: F80 M3
Hilarious. Thanks bud. You'd think those that own M cars would have their spelling, grammar and vocabulary mastered. I cheated on the test when buying the car
      07-14-2016, 02:47 AM   #4
docmfg
Drives: E46 M3/2016 M4
2009 MB C63  [0.00]
2012 BMW 535  [0.00]
2016 BMW M4  [0.00]
2003 BMW M3  [0.00]
Yup the newer type OEM wheel lug bolts are cheaply painted black as mine are showing silver at the edges. The bolts on my E46 are still black even after 14 years.
      07-14-2016, 02:50 AM   #5
m4chievous
Australia
24
Drives: 2016 BMW M4
Hey mate, we all love our cars. I get paranoid if someone parks close to me.
But your scenario I think it is unavoidable. Two hard surfaces placed under tension while in contact will cause unavoidable damage.
      07-14-2016, 04:16 AM   #6
AC-S
Registered Member
Australia
14
Drives: M4
I think they used a worn/old socket because I have taken mine off many times and not a mark on them
      07-15-2016, 01:32 AM   #7
brownb_2
brownb_2's Avatar
Australia
61
Drives: 2016 M3
replace them, then when you replace them and tighten and they get a scratch , replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten, replace again , then when you tighten, replace again, then when you tighten,
      07-16-2016, 12:08 AM   #8
AC-S
Registered Member
Australia
14
Drives: M4
or you can replace them with titanium non painted bolts, you will not see the difference then
      07-17-2016, 10:37 PM   #9
simpelton
Australia
33
Drives: F80 M3
In other words it's unavoidable!! Or
repaint them, then when you tighten, repaint them again , then when you tighten, repaint them again, then when you tighten...
Just saying - ya know - there are always options and choices in life.
Anyway, having them replaced
f80post
