07-17-2016, 07:08 PM | #1 |
Rep 275
Tint front windows or entire vehicle?
Headed to the tint shop and I've been reading the threads on here about tint matching. Looks like around 15-20% is the go-to for matching the front windows to the rear, but how many have gone ahead and tinted the entire vehicle (rear windows, back tailgate window, etc) and why?
07-17-2016, 07:54 PM | #3 |
Self-Deprecating Narcissist
7274
Rep 6,561
front only. matched to rears with light meter. no complaints except if i had to do it again i would go slightly darker to offset the light coming in from the windshield other than that front alone is just fine. (IMO)
07-17-2016, 08:31 PM | #4 |
Rep 8,364
It depends on with which tint film you are thinking and if you are going for look or also heat/ glare reduction. You can do a quality ceramic film with high vlt on factory tinted for improved IR block with needing to go as dark. It is simple multiplication of existing times added film factors for final stats. Even untinted front will have a 78-82% vlt.
I also tint front windshields with 70-80% vlt and it is amazing how much heat is blocked from large front. |
07-17-2016, 08:37 PM | #5 | |
Rep 462
Would the dealer notice a front 80-85% front windshield like llumar air blue or 3M crystalline. |
07-18-2016, 01:59 AM | #6 | |
Rep 8,364
07-18-2016, 05:44 AM | #7 |
SCHNELL
227
Rep 835
Said it before, and I'll say it again. What country allows you to tint a front screen?! Do you wear sunglasses to drive at night? If so, good work Corey Hart......
07-18-2016, 07:32 AM | #8 |
Rep 11,147
A tint does not equal limo tint. You can get a tint that does not make the windows darker but simply helps keep the interior cooler.
07-18-2016, 07:54 AM | #9 |
7274
Rep 6,561
i thought the OP was referring to the two front occupant windows on the side of the vehicle not the windshield.
07-18-2016, 01:50 PM | #11 | |
Rep 8,364
OP is, but many do not realize you can tint get front done and it makes a big difference. |
07-18-2016, 02:44 PM | #12 |
Rep 310
I went with 35% up front, a little lighter than the factory rears. I think 20% would probably match the factory tint perfectly.
2007 SG/Black e90 335i - Gone
2010 JB/Black e82 135i M-Sport - Gone 2013 JB/Black e90 335i M-Sport - Gone 2016 MBM f30 320i - Gone 2015 BSM/Black f15 X5 xDrive50i M-Sport - Current |
07-18-2016, 03:12 PM | #13 |
Rep 3,205
What I did on my X5M was 85% on windsheild, moon roof, and all oem tinted glass. Then had 35% put on the driver and passenger window. Used huper optik ceramic. Plan is to do the exact same to my F15 when I get it later this year. It looks clear on the windsheild and all the other glass has a perfect 35% look to it. Can't go wrong this way and the cabin is a much cooler place to be.
07-18-2016, 06:08 PM | #14 |
Rep 462
Laws in Toronto are as follows:
"the surface of the windshield or any side window to the left or right of the driver cannot be coated with any colour spray or other colour coating in such a manner as to obstruct the driver's view of the roadway, or obscure the view from outside to the interior of the motor vehicle. Based on the above, I can technically tint the front window if it doesn't interfere with my view at night. I think 85% let's more than enough light in and stops all of not most of the uv rays. Had to look that one up - thanks. |
07-18-2016, 06:26 PM | #15 |
Mmmmm…
1152
Rep 2,426
Drives: F15
I only tinted my front and windshield. I also didn't match. All I wanted was heat rejection, not a tint ticket.
07-19-2016, 07:11 AM | #17 |
Rep 518
We just recently did 3m color stable 35 for the front and crystalline90 for the front windshield on the 40e. The front windows are a great match to the factory in colour with slightly more transparency. Not sure though if I'm too impressed with the crystalline90 yet. Under fluorescent lighting in my garage you can see some form of purple circle hazing. The tint is not 100% clear. Not sure if it's because the tint still has to cure. Will see in a few more days...but because of this I cannot recommend the front windshield at this point.
07-19-2016, 05:59 PM | #19 | |
Rep 1,547
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
07-19-2016, 08:19 PM | #20 |
Rep 92
X6 (perfect color matching)
W 70% FD&FP 50% RD&RP 70% R 50% 4er W 70% D&P 50% R 50% This setup is quite neutral and not too dark to attract the attention of the police, but still provides you with decent level of privacy and heat/UV protection if you opt for a good film. |
07-19-2016, 10:07 PM | #21 |
Rep 8,364
I am surprised a 50/70% would color match. Are you saying FD/FP & RD/RP all look the same? Which film do you have this setup on X6?
07-20-2016, 08:14 AM | #22 | |
7274
Rep 6,561
50% on the front would not even be close to matching especially if you're tinting the rear windows over the factory tint they come with.
