07-25-2016, 08:31 PM | #1 |
Rep 62
Issue with parking brake 2016 f15
Not sure if anyone else is experiencing this but when I'm in my driveway on a hill and initiate the parking brake, When I turn off the engine the car has an additional slight movement as if the parking brake had slipped .
Did not experience this on my F10 so I'm wondering if I should bring to service . |
07-25-2016, 08:44 PM | #2 | |
Rep 592
07-26-2016, 01:17 AM | #3 |
<3 Flat Four
217
Rep 754
i personally have not experienced this much, and i noticed the only times the car moves after setting the brakes are if the car is held steady with the auto hold feature first and then setting the parking brakes. are u holding the car with auto hold first?
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
08-27-2016, 07:48 AM | #4 |
Rep 83
to paraphrase pragueX5 from the other thread:
1) press and hold brake pedal 2) engage Park on transmission paddle 3) turn off engine 4) release brake pedal this appears to work for me - the parking brake holds the vehicle vs. the transmission. yes, it is contrary to how we did this with cars for last century, but it is what it is.
2021 X3 M40i, 2021 X5 xDrive 4.0i
------------------------------------------------------------- 2016 X5 3.5i, 2017 X4 M40i, 2006 330i E90, 2004 X5 3.0i, 2000 528i MT, 1986 535is MT , 1985 528e MT, 1985 325e MT |
Jars914658.00 |
08-27-2016, 11:23 AM | #5 |
Rep 171
I doubt the vehicle is actually moving. When I engage the park brake on a flat service I don't get that jerk, I get it only when on an incline. I think its just the transmission releasing pre-loaded torque due to the incline but my X5 doesn't actually move overcoming the parking brake.
08-27-2016, 02:52 PM | #6 |
Rep 83
Initially I wasn't sure of what was happening with the new F15, so I did the following on an incline surface (from the days of owning a stick shift):
1) Depress and hold the brake pedal 2) Place the X5 in Neutral gear 3) Engage the Parking Brake 4) Place the X5 in Park gear 5) Release the brake pedal (car did NOT move) 6) Turn the engine off Immediately there was a sound from the parking brake (engage/disengage I don't know?). This was followed by a perceptible movement backward and then the car came to a stop. My sense was the car was held by the transmission. FWIW, I'm not sure there should have been any preloaded torque as I set the parking brake while in neutral gear, and then engaged Park gear. When instead I follow the procedure as described in previous post above - there is no audible parking brake sound when I release the brake pedal AFTER I turn off the engine. Also no shift backward?? Puzzled as anyone, but I think the latter protocol engages the PB properly for its intended purpose.
08-27-2016, 10:14 PM | #7 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Yeah mine seems to move a little. I always use the parking break. Never had a problem. I will probably take a look at the parking brake next time I do maintenance see how much wear the pads have.
08-29-2016, 10:02 AM | #8 |
Rep 1,547
Might just need a slight adjustment, just don't adjust it too far out, you don't want it 'dragging' when disengaged. Mine operates the same as the OP describes, seems to be normal across the board.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
09-06-2019, 06:24 AM | #9 | |
Rep 536
11-29-2019, 07:00 AM | #10 |
Rep 536
Feedback regarding this issue - I complained about this, and dealer actually investigated and did troubleshooting. Eventually, they replaced the complete parking brake mechanism (actuator, control unit, cables, shoes)
Car now behaves as expected - no movement when parking brake is activated and car switched off (just as my F13 did). It IS NOT normal behavior. Don't let lazy dealers BS you into this. |
11-30-2019, 08:28 PM | #11 |
Rep 7,588
Just an FYI as to why some "feel" like something is wrong with their parking brake...based on the info from the TIS, the front & rear hydraulic brakes are applied first, then when the engine is not running...the electro-mechanical (rear axle) drum parking brake is applied and the front/rear hydralic brakes are released:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-30-2019, 09:55 PM | #12 | |
Rep 115
