New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      08-09-2016, 10:22 AM   #1
Pudgypepper
Capitan Slow Mods
Drives: E70 X5d, E89 Z4 35i, E46 330Ci
Removal of Rocker Panels/sideskirts?
Has anyone done this? I can't find a write up on the web or maybe my search skills aren't good enough.
      08-09-2016, 11:45 AM   #2
hiltonfa
hiltonfa's Avatar
South Africa
13
Drives: 2011 3.0 Sdrive
Not a difficult job, I fitted side skirts to mine a while back. There's one bolt at the bottom of the front wheel arch and two underneath at the rear, there's about 7 expanding rivets along the bottom of the panel, remove all these and pull the panel outwards starting at the front, it's easier if there's two people doing this. There are are also clips holding it in place on the inside, use just enough force to unclip these. Be prepared for a few of these to break, you may be lucky, I had 4 broken after removing both sides. Hope this helps.
      08-24-2016, 05:55 PM   #3
Pudgypepper
Capitan Slow Mods
Yes, it helped very much!!!! Thank you so much!
      01-27-2017, 12:28 AM   #4
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
Can anyone share a few more specifics on removing the rocker panel? It's clear that there are bolts and expanding rivets underneath. What else does one remove? When pull, which direction? Do you slide it one way or the other to release the inside clips? If you are breaking them, you're likely doing it wrong, IMHO.
Thanks!
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
zpost
