08-11-2016, 11:13 AM | #1 |
Rep 1,523
lowered to the track ride height
Took my M4 GTS to the shop for them to lower it. I have attached pics of before and after measurements. Taking out the c-clips will give almost a even drop of .5" all around.
Take note that because the springs for the rear is located almost in the center point of the control arm (between hub and pivot point). For every 1mm of adjustment you make, it will translate to almost 1.5mm of ride height adjustment. The c-clips for the front is 15mm and the rear is 7mm, but it gave about a .5" drop in the front and .4" drop in the rear. Last edited by M4_GTS; 08-11-2016 at 11:27 AM.. |
08-11-2016, 11:25 AM | #3 | |
Rep 1,523
btw, since you guys own a shop, did my explanation of the rear adjustments make any sense? Last edited by M4_GTS; 08-11-2016 at 11:31 AM.. |
08-11-2016, 11:26 AM | #4 |
Rep 1,727
amazing. but that front plate hurts my eyes!
2017 C63 2012 X5M SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i |
08-11-2016, 11:29 AM | #5 | |
Rep 901
And yes, of course. It's all just Geometry at the end of the day |
M4_GTS1152.50 |
08-11-2016, 11:31 AM | #6 |
Rep 1,523
I have to run a front plate where I live. Every cop in town will pull you over for sure and give you a $137 ticket. I just have it on there with 3m double sided tape for now. I am still waiting for my personalized plates to be approved and then I will maybe use the tow hook mount from usmillworks.
08-11-2016, 11:35 AM | #7 |
Rep 1,523
That first tank of water was used on the Autobahn and also the alps in Europe during summer. So if you drive it in the city and not hammer on the gas all the time, it will last longer than the 5 tanks of gas. Also the weather plays a role, as it will use more in the summer months.
08-11-2016, 12:51 PM | #9 |
Rep 1,523
08-11-2016, 12:52 PM | #10 |
Rep 1,132
08-11-2016, 01:06 PM | #11 | |
Rep 901
I'm hoping there's a retrofit solution for it that is bulletproof soon. Would love to have this set up so I can say "Yeah my car runs on water." |
08-11-2016, 02:07 PM | #12 | |
Rep 1,727
08-11-2016, 02:25 PM | #13 |
Rep 1,523
08-11-2016, 03:12 PM | #14 |
Rep 137
Looks good M4_GTS. My plate mount arrived today, so thanks for the tip. I'm having my car lowered to the lock nuts not past?....I'm assuming you removed them and went past since you said race setting????
And I have less kms than M4_GTS but I have yet to fill up my water tank....I have 1500kms. |
M4_GTS1152.50 |
08-11-2016, 03:19 PM | #15 | |
Rep 1,523
I think that plate mount is the best solution for those that must run a front plate. |
08-11-2016, 03:58 PM | #17 | |
Rep 137
M4_GTS1152.50 |
10-12-2016, 03:32 AM | #20 | |
Large Member
951
Rep 1,749
2008 E92 M3 (Engine swap completed), 2015 F82 M4
10-12-2016, 09:27 AM | #21 | |
Rep 1,523
It was off the car because the front splitter was damaged during transport after the ED trip. BMW Canada had my dealer ordered me a new one and the paint shop needed the old one for color matching. At the same time I also had them repaired the damaged one. If you look at the most recent pic. The orange spitted is back on the car. The car looks way better with the orange front splitter anyways. |
10-12-2016, 12:31 PM | #22 |
Rep 230
So I have found that in street setting, I have pretty good clearance with the front splitter. I don't hit my driveway and I have not bottomed out on bumps that have my GT4 scraping horribly on the pavement. How is it in track setting for the GTS?
