08-13-2016, 02:11 AM | #1 |
Rep 54
JRZ suspension retrofit from F82 to E92??
Anyone know what is the different between the JRZ kit btw M4(f82) and our M3(e92)?
A local friend is parting out his F82. I want to know if the JRZ coilover for F82 could be retrofit to my ZCP E92. Even if it could be retrofit, will it work correctly? Thanks for any input!! |
08-24-2016, 07:32 AM | #2 |
Rep 2,342
You should call JRZ.
but my initial reaction is no. if the front shock length is the same then you'd only need new top mounts. I think the rear would be totally different since the two cars have different top mount styles in the rear. |
08-24-2016, 08:38 AM | #3 |
118
Rep 691
Agreed, if they were swapable they would be noted on JRZs site. But because both cars have different specs I highly doubt they will be able to work.
08-24-2016, 10:36 AM | #4 |
Rep 5,482
These higher-end dampers are usually more generic than you'd think in terms of fitment. They may only need a different top mount and bottom insert sleeve for the struts, and a different rear top mount setup. Call JRZ.
08-25-2016, 09:11 PM | #5 |
Rep 54
I contacted JRZ.
They said it could be done. However, the retrofit be pricey. I end up with a set of used JRZ RS Pro designed for my E92 . Guys, Thanks for the input!! |
08-28-2016, 09:28 PM | #6 | |
Rep 2,342
I have some badass AST's for my E92 but the JRZ's are a step up. |
