08-16-2016, 05:56 AM | #1 |
Rep 207
Install instructions for M Perf Brakes (ASAP access)
Can someone with access to ASAP send me the PDF of the instructions for the M perf. brake install? Part # 34112348054
Thanks |
08-16-2016, 08:41 AM | #2 |
Rep 18,794
@Cybertronic , if you need installation instruction to do a brake upgrade, I suggest you to have professional to do it.
It is brake system where your life is depending on. Please get it done properly.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
aw3051441.50 |
08-16-2016, 11:09 AM | #3 |
Rep 540
^^^ Good answer. Don't put your and other lives on the line.
08-17-2016, 03:57 AM | #4 |
Rep 207
Thanks for the non-answer to my question.
I was a BMW mechanic, and have done MANY brake jobs. I know what I'm doing. This is a straight forward caliper and rotor swap. I just need to know the VO code to add to the car after the installation. The instructions in the ASAP portal have this. Which was my question.... |
08-17-2016, 06:21 AM | #5 |
Rep 1,168
=> Connect
=> Expert Mode => Coding => Read FA => Save FA => Editiors and viewers => FA-editor => Go to HO-Wort and right click on "Edit," then type "SBRE" under the HO-Wort file => Select the FA, right click "Enable FA" and "Calculate FA" to verify that no errors are found after adding the SBRE => Check the vehicle profile to locate the "" aftermarket retrofit "and check" that you see something about 19 inch sport brake, forgot what specifically it said....note there is nothing about 20 or 21 inch because the. M performance brake kit for f15 supports 19 inch and up... It's four piston front not six that comes with f85 "has been added to the file => Write (write) FA to your car. No confirmation window will appear after saving the FA to the car => Expert Mode => Coding => Read (read) the FA. You are able to see SBRE be added to the HO-Wort folder on your car. => Read SVT, and locate the "DSC" (File Folder SVT / ECU / DSC), then right-click the "DSC" folder and select "Code". Consolidation should start immediately. => Allow the coding is over, and repeat step 1 to save a copy of the new FA. => Disconnect the car's computer. Ready to go it's done. |
08-17-2016, 02:39 PM | #7 | |
Rep 18,794
