04-01-2008, 05:08 PM | #1 |
John 14:6
59
Rep 588
New shocks?
Hey guys,
My Z4 has been lowered on Eibach's for the last 2 years, with the original Sach shocks. In my opinion, the ride quality has diminished, and I'm noticing a harsher, more sensitive ride. Should I upgrade to Koni sport shocks? Any suggestions. I just got an Eibach camber kit installed this past weekend, so this will be a perfect time to maybe invest in new shocks. |
04-02-2008, 01:25 AM | #4 | |
'Entwicklung 85 - Zukunft4'
26
Rep 238
"The Stage 1 Suspension System has been designed to address the foundation for performance handling. The system consists of a set of performance tuned springs and carefully matched Koni adjustable front strut assemblies and rear shocks. The system provides superior handling through increased grip and reduction of body roll, while maintaining a nicely dampened ride. The modestly lower ride height gives the cars a tastefully enhanced performance look as well as improving suspension geometry. The Koni struts feature externally adjustable rebound dampening via a knob located at the top of the strut. The shocks are also rebound adjustable, requiring removal for adjustment...." Others my feel otherwise, but in the end it will be your choice.... |
04-02-2008, 02:18 AM | #5 |
Rep 1,210
Since the Konis are adjustable you can have them at whatever ride comfort you want. So you can have it softer then stock, right at stock, or "feel every crack" stiff.
04-02-2008, 09:31 AM | #6 |
gone baby gone
382
Rep 1,052
An adjustable shock alone isn't going to give you THAT much flexibility. The "range" of adjustability will be determined by the spring rate of the springs you put on. (such as, from mushy to soft, or from stiffer than stock to too stiff.) Also remember that adjustable shocks usually only dampen the bound, not the rebound, so spring stiffness will play greatly into how hard the rebound is.
A mismatched shock and spring set can give a very mushy ride, such as where the car does not have enough time to normalize before you hit the next bump on a bad road, and you'll get a real rough travel. Just food for thought. |
04-02-2008, 12:54 PM | #7 |
John 14:6
59
Rep 588
Thanks guys for the advice. I'm going online to search for a reasonable price for the konis. Any suggestions on where to order them? I know 1st knight does his research before purchasing a product.
04-03-2008, 02:58 PM | #8 | ||
Rep 1,269
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe |
04-03-2008, 02:59 PM | #9 |
Rep 1,269
Shox.com.
04-03-2008, 03:02 PM | #10 | |
Rep 1,269
Same shock bodies. Totally different internal valvings.
04-23-2009, 10:45 PM | #13 |
Rep 615
he got them installed a year ago
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers -*MY PICTURE THREAD*- |
