09-29-2016, 02:47 AM | #1 |
Rep 151
Voltage Requirements ECU Flash
When flashing the ECU what is the volt requirement from the battery charger? Im trying to purchase a battery charger but only finding up to 12v and everything above that is over $100... Someone told me when flashing my ECU I need a MINIMUM of 20v... Is that true?
09-29-2016, 03:15 AM | #2 | |
BimmerPost Supporting Vendor
3391
Rep 7,543
12v should be your target minimum.. we've just tested for worse case scenario. Normally you'll see 12.1-12.3 on battery power with the ignition on, which is sufficient for a 10 minute flash. Not sure what you're using to flash but I'd contact your vendor and ask them. The "20v" you're referring to is likely 20 amps - nice to have a power supply that can output this, but by no means necessary.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
09-29-2016, 09:19 PM | #3 | |
Rep 151
09-30-2016, 12:28 PM | #4 | ||
3391
Rep 7,543
09-30-2016, 12:56 PM | #5 |
Rep 151
