10-08-2016, 11:55 AM | #1 |
Rep 296
***Official Wheel Thread***
Let's get an official wheel thread with the following format. Let's try to keep the post complete and accurate. username - wheels - size and offset - spacers - tires (size and brand) - suspension - clearance - does it rub (front back)? rolled fenders? |
10-08-2016, 12:00 PM | #2 |
Rep 296
username - tristanpaglia wheels - Niche Misano size and offset - 20x9 et 35 and 20x10 et 40 spacers - none tires (size and brand) - Bridgestone re760 sport 245/35R20, 275/30/R20 suspension - KW V3 Coilovers clearance - Initial slight rubbing front and back. [/QUOTE] username - Mr_Jack wheels - Velgen size and offset - 19x9 et35 and 19x10.5 et45 spacers - 18mm front, 12mm rear tires (size and brand) - 255/35/19, 295/30/19 suspension - H&R Sport/Bilstein B6 shocks clearance - Rubs up front backing out of an incline on the inner fender a tad, rear used to rub on stock shocks username - GRANTLDN wheels - x5 OEM wheels size and offset - 19x9, 19x? spacers - 15mm spacers front and rear tires (size and brand) - Pirelli P Zero 225/40/19, 255/35/19 suspension - BC coilovers clearance - 2 to 3 mm clearance username - AWF87M2 wheels - Style 351 size and offset - 18x?, 18x? spacers - none tires (size and brand) - 245/40/19, 275/35/19 suspension - BC coilovers clearance - ? username - BeemerX1 wheels - Style 405m size and offset - 20x8 et30, 20x8 et30 spacers - none tires (size and brand) - 225/35/20 Michelin Pilot Super Sport non runflats suspension - Bistein B12 kit clearance - ? username - Booster wheels - ? size and offset - 18x8.5 et29, 18x9.5 et23 spacers - 12mm spacers front, none rear tires (size and brand) - 245/40/18, 265/40/18 suspension - H&R Sports clearance - no rubbing username - Activ3 wheels - Rays size and offset - 19x8.5 et24 front 19x9.5 et36 rear. spacers - 20mm front, 12mm rear tires (size and brand) - 225/40/19 front and 255/35/19 suspension - BC coilovers clearance - does rub the rear sometimes. username - Mr_Jack wheels - Apex size and offset - 17x? et? spacers - none tires (size and brand) - 275/40/17 suspension - ? clearance - ? username - wantm135i wheels - Style 225m size and offset - 19x9 et35 square spacers - 15mm front tires (size and brand) - 255/35/19 squared suspension - KW Coilovers v3 with rear KMAC camber kit clearance - "better handling its a night and day difference." username - Mr_Jack wheels - Apex Arc 8 size and offset - 19x8.5 ET25, 19x9.5 ET22 spacers - 5mm front tires (size and brand) - 225/40/19 Hankook V12 EVo2, 255/35/19 Hankook V12 EVO2 suspension - H&R springs clearance - ? Last edited by D Unit; 10-11-2016 at 10:27 AM.. |
10-09-2016, 10:52 PM | #3 |
Rep 71
The white one on Velgens is mine.
username - ray340i's friend wheels - Velgen size and offset - 19x9 et17 and 19x10.5 et33 spacers - 18mm up front 12mm out back making it those specs tires (size and brand) - 255/35/19 295/30/19 suspension - H&R Sports/Bilstien B6 shocks clearance - Rubs up front backing out of an incline on the inner fender a tad, rear used to rub on stock shocks
'15 E84 X1 35i M Sport MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes '02 E39 530i 624whp/558ft-lbs @23psi |
D Unit92.50 |
10-10-2016, 10:29 PM | #5 | |
Rep 296
D Unit
Bay Area, CA |
10-11-2016, 12:24 AM | #6 |
Rep 71
19x8.5 ET20(had 5mm spacer up front) 225/40/19 Hankook V12 EVo2
19x9.5 ET22 255/35/19 Hankook V12 EVO2 I also used to have M4 wheels 19x9 ET29 and used 12mm spacer 255/35/19 19x10 ET40 and used 10mm spacer 295/30/19
10-11-2016, 10:45 AM | #8 |
Rep 296
Mr_Jack... You have a serious wheel problem. BTW, did you like the Velgens or the Apex Arc 8s better? I believe Apex wheels are flow formed, TUV and JWL certified. The Velgens VM804s you posted are also flow formed, but not sure if they are certified.
You guys think the x1 can pull off 17s with 225/45 and 255/40 tires (.9" smaller than stock). I feel so attached to these wheels since I had them shipped from Germany and refinished in Cali. It's not like the X1 is a big car, right? |
10-14-2016, 04:45 PM | #9 |
Rep 11,785
totally sweet. Actually might test fit my OEM wheels from my 1M for fun..
10-16-2016, 07:38 PM | #10 |
Rep 2,402
OZ Ultraleggeras from our M3, 18x8/18x9, ET40. 12/15mm spacers with 225/255 tires. H&Rs w/B6s.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
10-28-2016, 04:34 PM | #11 |
Rep 1,397
winter mode! 18x8 manufacturer offset (specific to a 3 series) iForged Performance Daytona 2 piece wheels and Nokian Hakkapellitta 225/45/18
summer wheels to come once I do my B6/H&R setup. Last edited by neverdone; 10-29-2016 at 01:02 PM.. |
11-20-2016, 04:03 PM | #13 |
Rep 4
@Mr_Jack, those tires look awesome, LOVE IT! That's exactly the look I've been trying for, smallish rims (17") with huge meaty tires. Is that size right, are those really 275 width R17 tires on there, and they fit okay with no spacers?
wheels - Apex size and offset - 17x? et? spacers - none tires (size and brand) - 275/40/17 |
01-31-2017, 10:36 AM | #14 |
Rep 4
Looking to put some 19's on the wifes X1. Whats the widest I can run fun and rear? I see Mr Jack has 295's but it sounds like its a pretty tight squeeze. Would a 275 rear 255 front be better?
01-31-2017, 11:59 AM | #15 |
Rep 1,343
I'll contribute. Winter set.
username - Gamb1t wheels - BMW 5-series E60 Style 138 size and offset - 17x7 ET20. Abit aggressive offset for a flushed look. spacers - None tires (size and brand) - Triangle Snow Lion TR777 225/50/17 suspension -Stock clearance - No rub anywhere. |
03-05-2017, 07:14 PM | #17 |
Rep 132
- Username - tony3series
- Wheels - BMW style 355 - Size and offset - Front: 8"x18" ET30 Rear: 9x18" ET 41 - Spacers - None but thinking about getting 15-20mm rear & 12.5-15 front - Tires Size - Front: 225/45/18 Rear: 255/40/18 Brand: Sumitomo HTR A/S P02 - Suspension - Stock Msport. - Clearance, does it rub? - Well it's stock Msport so no rub yet HaHa I ordered B12 kit with Eibachs & Bilsteins. Should give a 30mm drop. Will post pics after installed. Also.. thinking about getting some VMR V710's 18x8.5 ET 20 front and 18x9.5 ET 22 rear. |
03-15-2017, 10:33 PM | #18 |
Rep 83
Just picked these up, got a deal I couldn't pass! style 166 off an E60 M5
19x8.5 et12, 19x9.5 et28 The front offsets are obviously pretty low but I think (hope) they'll fit without any real issues. I'll be test fitting them in the week or two before I order tires. Will do an "official" post once I get them on and drive them!
2013 MG X1 x35i M Sport
03-16-2017, 05:49 PM | #19 | |
Be Original.
267
Rep 523
03-17-2017, 02:39 AM | #20 | |
Rep 83
it's stock M sport suspension so I'm not worried about rubbing. The front offsets are only a few mm (literally around 0.04 of an inch) lower than some of the other set ups on here, but a narrower rim. So I'll see how the test fit goes. But even if I hate it, no harm no foul. I still have the oem 225's.
03-17-2017, 09:02 AM | #21 | |
Rep 435
Here's 18x8 et13 with just a slight poke on the front. Your going to be 7mm farther out, so basically the entire lip will be outside your fender, but that's about it. |
03-22-2017, 04:06 PM | #22 | |
Rep 1,343
