10-11-2016, 07:18 AM | #1 |
Rep 82
Drives: F80 M3 YMB/BLK 6MT
brake pad wear
Ran Time Trials at Road Atlanta this weekend and when I removed my track pads (Pagid RS-29s) the front pads were worn at an angle (like one piston is pushing harder than the other). Anyone seen this before and know what causes it?
2015 F80 M3 YMB 6MT
2012 E92 M3 Space Grey DCT - Sold 1991 Z32 300zx 2+2 TT 5MT |
10-11-2016, 08:08 AM | #2 |
FAST
371
Rep 574
I really don't have any issues with the RS-29s Some of the best pads I've used. (And I've been through a lot)
I do get some angle, but not much. What I normally do is after 2 days of running, (And if the rotors are in good shape) swap left to right, inner to outer. If there is too much grooving, I don't swap, just leave them be. I also run cooling ducts... I have bigger issues with my "Tires worn at an angle!" Stock alignment stinks on these cars. |
10-11-2016, 09:24 AM | #3 |
Rep 103
Some taper front-to-back is normal. The leading edge might get a couple of mm more worn than the trailing edge by the time the pads are done. If it's more than that you might have some kind of problem.
10-11-2016, 01:25 PM | #4 |
Rep 20,742
Drives: 2021 911 turbo
I also observed tapered wear on my front RS29. I guess it is the drawback of multi piston calipers. On my first set, I only noticed when the pads were worn, so the taper was quite significant, about ~4mm from leading edge to trailing edge. Since then, I swap the pads inside out when they are half worn. This has resolved the issue for me.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
10-11-2016, 01:48 PM | #5 |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
I measured a 5.5 mm spread on leading to trailing edge of the front pads (RS29).
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
10-11-2016, 07:12 PM | #6 |
FAST
371
Rep 574
5.5mm is a problem. That is like 1/2 the pad! Shouldn't be that bad. Normal would be like 2mm max if you never rotate.
FYI I measure pad thickness at every swap. The BMW pads are really small length wise. |
