10-18-2016, 09:12 PM | #1 |
Rep 215
KW Knock
Alright guys, I've got an E90 M3 on Clubsports and I've had a knocking noise that happens at low speeds over rough roads. The noise is very apparent and annoying. It sounds like sway bar end links/ball joint but I eliminated sway bar end links and just recently noticed the knocking is dependent on the dampening settings. Currently it is only on the driver front. On soft the noise is gone, on stiff the knocking is there. I know I can just set the dampening to soft and call it a day but I know the knocking shouldn't be there either way. So, has anybody else come across this or self fixed this? I've been emailing KW with no help or insight. I can bounce on the driver front sill plate and clear as day hear it knock... I appreciate any input, thanks in advance
10-20-2016, 10:56 AM | #3 |
Rep 215
10-20-2016, 04:38 PM | #4 |
Rep 5,508
If you have pillowball upper mounts, it could be those making noise. Pillowball spherical bushings wear out and need to be replaced. It definitely sounds like it because the sound changes with the dampening setting - the shock is moving more/less against the upper mount. Also, check the upper center nut to make sure its tight.
I've had a lot of pillowball clunking from coilovers in the past. I refuse to run them on the M3 for that reason.
Auto Detailing Enthusiast!
11-02-2016, 11:37 PM | #5 |
Rep 215
UPDATE: Still chasing the issue Ended up removing the strut and disassembling it and inspecting piece by piece. I ended up finding some play in the unibal, you're thinking "well then theres your issue..." right? Except idk if its suppose to have play or not.. I am thinking not.. the video I attached (hoping it works) I also Emailed to KW with no response... I am hoping some suspension guru on here may be able to give me more insight?
Volume required, please excuse the dog paws on the hardwood lol https://drive.google.com/open?id=0By...m5FVHMtdHdMaDg Top view, where camber plate sits https://drive.google.com/open?id=0By...nJtLVRvT0J0dWc Side profile |
11-14-2016, 06:38 PM | #6 | |
Rep 5,508
11-15-2016, 11:34 AM | #7 |
Rep 215
If the pillow ball was bad then shouldn't I be able to feel play in it? because I had removed it from the strut to inspect it and it was solid, I couldn't even rotate the ball by hand. It's pretty snug in there
11-15-2016, 11:39 AM | #8 |
Rep 5,508
You should yank on it with while mounted to the car to see if there's any play. No way can you move that thing with your hand. It's designed to hold up the weight of the car, it takes a lot more weight/force to be able to move it.
11-15-2016, 10:49 PM | #9 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
A common problem with KW clubsports is over-torquing of the spring perch set screw in the front. This causes the screw to strip (or more accurately the spring perch's plastic set-screw threads strip). The threads are plastic and the screw is metal. It's easy to over torque them. I found that if/when that screw was stripped then the spring perch was no longer in a fixed position and moved when the suspension articulated. I would hear a noise when it did so. Check it out.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
11-16-2016, 09:16 AM | #11 | |
Rep 215
11-16-2016, 09:18 AM | #12 |
Rep 215
11-17-2016, 05:17 PM | #13 | |
Rep 6,218
ill draw with a red sharpie and see how it changes over time.
11-21-2016, 09:32 AM | #14 | ||
Rep 6,734
'23 X7
