10-28-2016, 12:11 PM | #1 |
Rep 29
How to change display from EfficientDynamics to current M DDC modes?
Hi does anyone know why my f80 m3 showing this Efficientdynamic map, but I saw others all showing Settings of the car.
10-28-2016, 12:16 PM | #2 |
Rep 20,742
Drives: 2021 911 turbo
Go in iDrive, under Settings -> Instrument Cluster. You can change it from there:
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 10-28-2016 at 12:21 PM.. |
01-15-2017, 01:35 PM | #4 |
Rep 5,623
► Replace Regen/Efficiency Bar ?
on my my17 m4, below the tach i have a brake regen/efficiency bar.
is there a setting i am overlooking to replace with the older display of drive modes pictured below?
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
01-15-2017, 01:48 PM | #5 |
Rep 710
There's a setting at the top of the options you can go and change it. I'm not near my car so I can't look but you can change to either efficiency or the different modes as pictured.
01-15-2017, 02:19 PM | #6 |
Rep 4,823
Are you referring to the Drive select mode indications for throttle, suspension and steering plus transmission shift mode? All are set based on Drive modes selected. You can remove the indications from display via an idrive menu.
Edit: unless BMW changed it for 2017 it should be the first check box in "Settings" then "Instrument Cluster".
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
MPoweRo428.00 |
01-23-2018, 05:53 PM | #7 |
Rep 250
How do I get modes to show instead efficient?
Just got my car today.. how do I get it to show what settings I'm in like sport+ etc instead of it just saying efficient?
2018 M3 Comp
01-23-2018, 05:57 PM | #8 |
Rep 5,056
01-23-2018, 06:14 PM | #9 |
Rep 250
Thank you.
2018 M3 Comp
