11-05-2016, 06:06 PM | #1 |
Rep 337
MA shop for rod bearing replacement?
Looking to have my rod bearings replaced in the spring (car will be going into hibernation next weekend for the winter), and it's not something I'm comfortable doing on my own. Anyone else have it done anywhere in MA with positive results? I emailed Turner to do it and they want $3200. That seems excessive to me, but maybe that is the going rate. Any info is appreciated. Thanks.
11-05-2016, 07:06 PM | #2 | |
Rep 24,962
I would not care about the 3K , think 3K is a lot cheaper than a new/rebuild S65 engine from BMW...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
11-06-2016, 07:47 AM | #3 |
Rep 10,686
Its $500 to $1000 in parts depending on what you use and it will take a shop that has done it a few times about 8 hours though book time may well be 12 hours. Looks to me like Turner wants at least $2200 for 8 hours work, which is a ripoff.
No special knowledge is required to change bearings. Just good tools, care and patience and a fair level of competence. |
11-08-2016, 09:55 AM | #5 |
Rep 19
Never got rod bearing replaced but did get a new clutch and flywheel replaced at Precision BMW in Brentwood NH. Derek, the owner, is a great guy and does amazing job. He worked for Turner Motorsport and BMW dealer before opening his own shop. You could literally eat off his shop floor but would not recommend. Its how thorough and anal he is with the work space and cars.
11-08-2016, 11:15 AM | #6 |
Other car was a submarine
94
Rep 704
I had mine done at VSR in Bow, NH. Talk to Mario (the owner) or Chris (his son) and you will be all set. It's a small shop that specializes in vintage BMW restoration but they still build race engines for one of my friends and do anything and everything BMW wise.
I couldn't be happier with them and they are the only ones that I let work on my M3. For perspective I live in Central, CT so It's a 2.5 hour drive just to get there. |
11-08-2016, 06:47 PM | #7 |
Rep 1,390
Drives: 2012 E92 M3
I think the whole rod bearing issue is really inflated. I've asked my dealer if they have done any replacements or know of any motors that have blown up and he said no. I then asked if they service many M3's and he said he's has a lot of them that come in for service...
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) |
11-09-2016, 06:40 AM | #8 |
Rep 10,686
That is one theory -- that the failures are just a small percentage and most people have nothing to worry about. I would have to agree that, so far, the odds are with you. But almost all the bearings that have come out of cars for replacement have been heavily worn. I think the failure rate will increase as the cars age, but that it will still be a minority of cars that are affected. I chose not to take the risk, since I could do the change for $600 and I could not afford a $10k used motor.
Regular bearing changes are recommended by some E46M3 tuners, and BMW did a recall on the S54 bearings, so the possibility of real problems is not unheard of. Its unfortunate, but the failures are a reality that each person has to decide whether to address preventatively or that the odds are with them and nothing is needed. |
11-09-2016, 08:34 AM | #9 | |
94
Rep 704
11-12-2016, 07:41 PM | #10 | |
Rep 173
http://www.vsr1.com I think I saw your car up on the lift when I was there this summer. Space Grey Coupe? You had also hit some curbing and bent part of the exhaust system? They had the bottom of the motor removed and were doing the bearings. |
11-16-2016, 01:20 PM | #12 | ||
94
Rep 704
11-16-2016, 09:17 PM | #13 | |
Rep 337
11-17-2016, 08:24 PM | #14 |
Rep 10,686
They are right down the road from me in NH. They have a good reputation and have restored some older bmws very nicely. Not cheap, but NH is tax free.
11-18-2016, 07:42 AM | #15 | |
Rep 1,498
Drives: 2017 MB C63 S AMG Coupe
2017 MB C63 S Coupe - DINAN | MODAL WORKS
retired: GranTurismo MC, Giulia Quadrifoglio, B8.5 RS5, Q60 RedSport, e82 135, F80, e92 M3, e90 M3, (2) e92 335, B8 S4, C209 CLK55 AMG, e46 330 |
11-18-2016, 09:07 AM | #16 | |
Rep 876
Did you supply the rod bearings/bolts or did the shop? Did you use BMW bolts or ARP bolts? |
11-18-2016, 09:08 AM | #17 |
Rep 876
11-18-2016, 09:46 AM | #18 | |
Rep 1,498
He can get them for you if you want I imagine, he offered to get me the internal gears for the throttle actuators.
oolas3388.00 |
11-18-2016, 10:41 AM | #19 |
Rep 10,686
Stock bolts may not save you any money. The cost less to buy, but the labor to install stock bolts is three times that to install ARP bolts due to the factory bolt install procedure that has you going through 3 torque sequences twice for each of the 16 bolts. No doubt it costs over an hour. I have done it both ways.
11-19-2016, 08:02 AM | #20 | ||
94
Rep 704
oolas3388.00 |
03-17-2017, 03:07 PM | #21 | |
Rep 337
03-20-2017, 08:36 PM | #22 | ||
94
Rep 704
