11-11-2016, 04:23 PM | #1 |
Rep 58
H&R Vs Eibach on M adaptive
Hi Guys
Which of the two springs H&R/Eibach on M adaptive suspension - 1. Best for overall ride comfort and handling 2. Sit highest as I dont want it fully slammed thanks |
11-12-2016, 08:57 PM | #2 |
Rep 561
Not sure that anyone here has tried both. Maybe? Anyway the H&R's definitely set the car nicely, but whether you think they are low is another matter. I will say, specifically with M adaptive, that the rear spring/shock dampening combination is not correct. The car rides a bit stiff but more importantly the rear end is not set in spirited driving when the road surface and angles are not near perfect. Rather un-BMW. I suspect this is why so many street Z4 drivers are going to Variant KW3's. I initially didn't as frankly coil-overs are ridiculous overkill for a street car. But that said, if one can't get the springs and shocks working well together ... coil-overs it is.
KW3 owners also claim a softer, smoother ride. I will probably stick with the Eibachs for a while, as the coil-overs are a good drop of changed and I've been plumbing $$$$ into my car these last six months. See what others have to say, though ... Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport. |
Tags |
h&r eibach springs suspension |
