11-22-2016, 10:55 AM | #1 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
Battery Tender
What battery tender are you all using on your f85/f86 X5M/X6M?
Thank you. Eric
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
11-22-2016, 11:42 AM | #2 |
Rep 2,775
Drives: F95 X5MC
Deltran Battery Tender...on sale now at Costco. I have three, one for the X5M, M3 and Corvette.
http://www.costco.com/Battery-Tender...100241973.html
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
11-22-2016, 12:04 PM | #4 | |
///M Fan
366
Rep 2,159
11-22-2016, 01:29 PM | #5 |
Rep 494
I'm using a CTEK 8amp universal charger, same make as BMW's proprietary one, but able to charge many more battery types. It has advanced battery management functions and can remain connected for months without any user intervention.
All recent BMWs use AGM batteries (Absorbed Glass Mat), therefore set the charger for AGM battery type (slightly higher final voltage). First thing after parking in my garage I always connect the charger; the idea is to externally power the cooling fans and pumps - who may run up to 15 min after engine shutdown - with the charger instead from the battery. I believe that the electrical energy used by these cooling cycles - probably 1-3 Ah each - is the main reason for the short battery life of our cars. |
11-22-2016, 01:32 PM | #6 | |||
Rep 2,775
Drives: F95 X5MC
From RealOEM.com: Original BMW battery Original BMW AGM-battery 50 AH 1 61219364597 Note: The installed 90Ah AGM battery is to be replaced by the 92Ah AGM battery! 01 Original BMW AGM-battery 92 AH 1 08/2017 61216924023 $520.08
AlexLou122295.50 |
11-22-2016, 02:07 PM | #7 | |
Rep 592
+1
11-22-2016, 02:34 PM | #8 |
///M Fan
366
Rep 2,159
Thank you so much.
11-22-2016, 02:41 PM | #9 |
Rep 2,775
Drives: F95 X5MC
11-22-2016, 10:41 PM | #10 |
Rep 254
Where does the battery tender hook up on the F85 x5m?
Current: 2019 M5 Competition | Frozen Black | Black Extended Leather | Executive Package | 706M 20" (winter) | ANRKY AN14 21" (summer) | Remus Exhaust | High Flow Air Filters | XPEL Stealth
11-23-2016, 07:06 AM | #12 |
Rep 2,775
Drives: F95 X5MC
Under the hood, on the right hand side you'll see a red battery terminal with a cover. There's also a hex nut for the negative (black) connection.
I found this photo on the internet...looks similar to the F85 X5M connections:
11-23-2016, 06:08 PM | #13 | |
Rep 254
11-24-2016, 03:54 AM | #14 |
Rep 374
Don't think so, but some battery tender comes with flat wire which you can close the hood when it's charging, this way you don't have to stress the hood struts.
992 Turbo S
X7 M60 |
11-24-2016, 07:54 AM | #15 |
///M Fan
366
Rep 2,159
They actually come with two set up, the traditional alligator clips, or round loops that you can bolt on to the battery post. In our X5M, you can't use those, because you must plug in the front, that way you can charge both batteries at the same time.
11-25-2016, 11:05 PM | #16 |
Rep 126
ok - so could you please post a couple of photos of what you're suggesting?? silly question - but by 2 batteries - you mean BOTH the a) 90mAh & b) 50mAh ?? |
11-26-2016, 08:34 PM | #17 |
///M Fan
366
Rep 2,159
That is exactly what I meant. The front connector unders the hood connects to both batteries.
11-28-2016, 02:33 PM | #18 |
Rep 1,170
I bought one too. These battery tenders just "top off" the battery life, so it doesn't extend the battery life, right?
2001 X5 4.4i - sold but never forgotten!
2014 X5 xDrive50i |
11-28-2016, 03:28 PM | #19 |
Rep 4,532
In theory they can extend the life of the battery. Batteries have a limited cycle life. They cycle down each time they are left unattended without a tender for an extended period of time. The BMW electronics puts a constant drain on the battery. The tender stops the drain and stops that cycle.
kanvas649.00 |
11-29-2016, 10:14 AM | #20 |
///M Fan
366
Rep 2,159
It actually can extend the life of the battery. I have an '09 e92 M3 and it has been on the battery tender ever since I bought it. Well whenever I'm not driving it. It is going on 8 years with the same OEM battery. It starts at the first try with no hiccups. So if I know that I'm not going to drive my car for more than a week, it gets plugged in. I have 4 of them, 1 for the X5M, 1 for the M3 and 2 for my two motorcycles. Non of them I drive daily. I have a BMW i3 that is my daily. I know, too many toys.
11-29-2016, 11:15 AM | #21 | |
Rep 2,775
Drives: F95 X5MC
My '08 E92 M3 has been on a battery tender since Day 1 also, and I just replaced the battery, not because it was necessary, but I figured an 8 year old battery should be replaced.
kanvas649.00 |
11-29-2016, 01:22 PM | #22 |
Rep 1,170
Thank you for the responses! All very helpful. I made a good investment Just charged my other car and it needed 2 full hours of charge.
2014 X5 xDrive50i |
