04-10-2008, 12:46 PM | #1 |
Rep 610
Carbon Fiber Driveshaft
Has anyone ever had a carbon fiber driveshaft on their previous cars? What were your opinions?
I contacted www.pstds.com and they said they can custom make a CF drive shaft in 2-3 weeks for ~$1000. You just need to take all the measurements that they require. Since I have never read any negatives about it I just may follow through. |
04-10-2008, 01:18 PM | #4 | |
Rep 610
correct essentially the ideal thing would be to lighten the entire drive train all the way to the tires. clutch, flywheel, light weight drive shaft, rotors, wheels, and tires. |
04-11-2008, 08:11 AM | #6 |
Rep 1,429
Makes for an easier throw. Once you get weight moving, it takes more to stop it. So once you start the shift, the knob helps put it in gear. I was shocked at how much difference a weighted knob made. And a weighted knob isn't rotating mass, so it has no effect on the rest of the drivetrain.
04-12-2008, 07:40 AM | #10 |
Rep 8,033
I just bought a set of CF tires...
Seriously, how much of a reduction in the moment of inertia of the driveshaft are we talking about by going CF and what is the significance of that in relation to the moment of inertia of the other rotating masses? I am pretty sure the M3 has a hollow shaft and they've done whatever they could have to keep "I" of the crankshaft low. Lighter wheels seem like a more obvious target to me rather than the shaft.
04-12-2008, 08:46 AM | #11 |
Rep 4,128
Drives: M235i & G30 540i
My car will have CF valve stems. Less rotational inertia means better handling lol
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
04-12-2008, 11:28 AM | #12 | |
Rep 431
04-14-2008, 07:01 PM | #13 |
HUSTLER
14
Rep 1,317
Speaking of CF Driveshafts, Here is TazaM3 with his 1000hp
Turbo'ed E46 M3 with a Broken CF DriveShaft! [u2b]<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/acME2-ElLGM&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/acME2-ElLGM&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>[/u2b]
E92 M3 ZCP- AW/FR w/Extended Leather) Packages: ZCP, 6MT, Fully Loaded E46 M3 - AW/IR 6 Spd, Fully Loaded. 19'' BBS LM DBK, V-CSL C/F Bmpr, Botld, Diff, V-CSL Custum IR-CF Center Counsel, V-GTR Hood, Dixis Ti 76mm, Meisterschaft Ti Sec. 1&2, EvoSport Headers, CAI, D/A Chip, tck d/a, Alcantera Headliner with Imola Red Sttitching.... |
04-14-2008, 08:00 PM | #15 |
HUSTLER
14
Rep 1,317
04-14-2008, 09:59 PM | #16 |
Rep 924
Drives: Ford Falcon Ute, Ducati 1198S
Can someone please post a link to the CF tyres, windows and pistons?
Thanks!
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
04-14-2008, 10:02 PM | #17 |
Rep 1,429
If you could piss away tens of thousands of dollars on the car like he has, you would laugh too.
04-14-2008, 10:13 PM | #18 |
Rep 8,033
No, I wouldn't.
01-03-2016, 04:08 PM | #20 |
Rep 139
'09 E90 M3 DCT EDC, ESS VT2 625, ESS HFC, GTS DCT, D2R BBK, B16D, VORSHLAG CP, DELRIN SUB, TE37SL
'00 996.1 GT3 CS |
01-04-2016, 12:13 AM | #22 |
Rep 81
Drives: NA
+1 Fall Line Motorsports carbon fiber driveshaft. Great product and excellent customer service from IND. Search ashtaron14 for full review on the Fall Line carbon fiber driveshaft.
