KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
01-20-2017, 02:56 AM | #1 |
Rep 92
Drives: 2011 E92 M3
Quick Triple Check Before I Order My Rims
Car: E92 M3 Coupe
Suspension: KW Sleeve Kit (Max Low front / 0.5" from max low rear) Wheels: Forgestar F14 SDC Tires: Hankook V12 EVO 2 BBK: not currently but would like to in the future Here's what I'm gonna order unless someone says otherwise: FRONT: 19x10 +19 275/30/19 REAR: 19x11 +27 295/30/19 I've done extensive research and this seems like what I want. My main concern is that the fronts are too aggressive. I don't want my front wheels to stick out more than my rear whees. I originally wanted ET23 but was told that BBK only supports ET19. Thoughts?
2011 E92 M3 / Alpine White / Fox Red / 6MT / CNT Racing / Forgestar F14 19x10 +19 265/30R19 19x11 +25 295/30R19 |
01-20-2017, 08:32 PM | #2 |
Rep 1,239
Here's what my forgestar SDC f14 with 20 offset 275/30/19 looks like on stock suspension. I would go 9.5" fronts if I were you. My setup is square so the rears are sunken in and the fronts poke out. I had to put a 12mm spacer in the rear to even it out. Hope this helps your decision.
A job is nothing but work.
01-21-2017, 03:57 PM | #3 |
Rep 92
Drives: 2011 E92 M3
thanks monterey . Looks like if lowered it will be perfectly flush. I see a lot of you out there running 19x10 +20 setups. Any of you lowered on KW HAS able to chime in?
01-22-2017, 12:11 PM | #5 |
Rep 3,982
Agreed, I would go ET25..
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
01-24-2017, 01:42 PM | #6 |
Rep 1,055
Yep, I tried 5mm spacers on 19x10 ET 25 front wheels and they poked out too much, spacers were removed and I am flush now on stock suspension.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
