New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      02-12-2017, 08:39 AM   #1
Vetracr
Drives: 2010 BMW Z4 3.0
H&R rear sway bar end link problem
See engine, transmission, ecu mod section for solution to H&R rear sway bar end link problem
      02-17-2017, 10:33 AM   #2
rking117
Drives: Z4 3.0i & 320i
One might open this thread and think to themselves. So what is the question or concern?
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
      02-17-2017, 08:12 PM   #3
Vetracr
Any one who has installed the H and R rear bar would understand at once.
      02-19-2017, 06:14 AM   #4
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
http://e89.zpost.com/forums/showthread.php?t=1353200
In my experience, H&R rear sway bar with stock end links, 1) the bar is too close to the half shaft if the suspension gets unsprung, 2) the loosest setting can not be set with the stock end link, 3) the rear end felt very squirrelly with the stock end link.
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      02-19-2017, 06:19 AM   #5
fmorelli
fmorelli's Avatar
Actually they may not (though you are right, they should). Unsprung the end link/sway bar almost hit the half shaft ... super close ... lots of folks aren't going to realize that, under momentum, everything moves around and those components will over extend (from static unsprung one sees).
It should be upgraded, as you show. Foolish not to, IMO. The nylon washers are a good solution. In my case we machined metal spacers.
Filippo
zpost
