BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      03-04-2017, 08:33 AM   #1
biasrutus
driver
20
Drives: 2011 e90 M3
Shopping Tires for e90 ZCP and spacers
Looking for feedback, all help appreciated!
I am about to buy new tires and think I want the GTS setup. The tire selection is limited though. I am not look for the actual GTS tires as I want to get some life out of the tires.
I have a ZCP with 12mm spacers in the front and 10mm in the back.
I am considering these two setups:
OEM setup of 245/35/19 and 265/35/19 with Pilot Sport 4s
vs
GTS setup of 255/35/19 and 285/30/19 with Potenza S-04 Pole Position (16 total pounds heavier)
cart screenshot
What I am trying to figure out:
Do I want the GTS setup more or the Pilot Sports more?
If I go with the GTS, will my spacers need to be removed or changed?
      03-06-2017, 04:51 AM   #2
biasrutus
driver
20
Drives: 2011 e90 M3
Using this site: https://tiresize.com/comparison/ it looks like GTS tires sizes are .8 in wider (20mm) in the rear and .4 in (10mm) in the front.
Seems like the tires would be an additional 10mm closer to my fender in the rear and 5mm closer in the front.
I am assuming this would be like running 17mm front spacers and 20mm rear spacers.
Then I found this post: http://www.m3post.com/forums/showpos...7&postcount=12
      03-06-2017, 05:29 AM   #3
GeorgeA
GeorgeA's Avatar
Drives: E92 M3
I think a lot of people do 255/35 and 275/35 on ZCP wheels and PS4S comes in that size.
      03-07-2017, 12:42 AM   #4
becausephilchow
Drives: 08 E90 M3
I would run 255/275. You can still run, I believe, a 12MM/10MM setup even with the +1 sizes. Could be wrong, I looked into it a long time ago.
I know people were able to run 15MM/12MM on 245/265 sizes.
Keep in mind, this is with the OEM 220M, which are 8.5/9.5. When you run a 255/275, it runs "beefier/fatter" than it would on a 9/10 ZCP Setup.
Also depends on how low you are, but, I'm leaning towards 12MM Front and 10MM Rear to be OK with 255/275 on ZCP Wheels.
As for GTS Wheel sizes, truthfully, I don't really like that for a non-GTS Vehicle. Why? Because our cars are coded from factory, the speedo and mileage counter, to recognize 246/265. The GTS from factory, surely is coded to recognize the 255/285 setup, which has a slightly different aspect ratio.
OEM Sizes = 1.081
GTS Sizes = 0.958
      03-07-2017, 06:26 AM   #5
biasrutus
driver
20
Drives: 2011 e90 M3
Pulled the trigger on:
MICHELIN PILOT SPORT 4S
Front: 245/35ZR19
Rear: 275/35ZR19
I am looking forward to being able to have traction again!
      03-07-2017, 09:32 AM   #6
becausephilchow
Drives: 08 E90 M3
Front: 245/35ZR19
Rear: 275/35ZR19
Should size up to 255/35/19 up front, but that's just my opinion.
m3post
