03-10-2017, 05:23 AM | #1 |
Rep 86
Help! My M3 is leaking oil!
Just picked the car up a week ago and noticed it's leaking oil! Traced the leak and it seems to be coming from oil housing unit. Could it be the gasket???
03-10-2017, 05:29 AM | #2 |
Rep 122
03-10-2017, 06:01 AM | #5 |
Rep 251
First make sure the cap is screwed on tight. If it is, then remove it and check if the o-ring around the cap is in place and isn't twisted. These usually come with a replacement oil filter. It wouldn't hurt to just get a new filter and replace it and the o-rings and torque the cap correctly. If that doesn't work you may need to replace the cap or the housing.
You can see the o-ring in the filter kit: http://www.autohausaz.com/search/pn....08UaAm6P8P8HAQ |
Theodore673.50 |
03-10-2017, 08:07 AM | #8 |
Rep 252
Check the cap of the oil filter housing. There is a o-ring around the cap that could be out of place causing the leak. If there is oil on the oil filter housing I would say the cap is the issue.
If you see oil under the oil filter housing I would say the oil filter housing gasket is leaking. Which is a gasket that seals the mating surface of the housing against the engine. |
03-10-2017, 09:50 AM | #9 |
Rep 1,678
Drives: 2011 MCB E92 M3
This. My wife's X3 got an oil change and they didn't fully tighten it and oil was all over the place afterwards. If it's completely tightened I'd get a new gasket.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
03-10-2017, 09:50 AM | #10 |
Rep 122
So i had the same issue. Noticed oil leak on my belly pand and it tracked to oil filter housing. I thought it was oil filter cap O-ring which was not. Then replaced oil cooling hoses O-rings, still leaked. It ended up being a crack in oil filter housing above oil cooling ports. It only leaked on cold start. I had to replace the oil filter housing which is pain in a a$$. You will have to remove pretty much everything from the front inculding radiatior and much more. So just make sure you do a right inspection and O-rings before anything else.
03-14-2017, 09:41 PM | #11 | |
Rep 52
Did you do the replacement yourself? I saw somewhere that the factory procedures mentions that you have to remove the harmonic balancer. Were you able to do so without removing it? EDIT: Doesn't appear as if you have to do so from another thread, will reference it below (although the BMW service procedure specifies it...)
2008 E90 M3 Jerez Black
2007 Mini Cooper S (The Radio-Active Concert Hall) 1993 RX-7 (self fabricated parts/far from stock) 1990 MX-5 turbo (self fabricated parts/far from stock) Last edited by bond_007; 03-14-2017 at 10:22 PM.. Reason: Additional info on seal replacement |
03-14-2017, 10:19 PM | #12 |
Rep 52
...this thread appears to have some good info on the seal replacement:
http://www.m3post.com/forums/showthr...ght=oil+filter
2007 Mini Cooper S (The Radio-Active Concert Hall) 1993 RX-7 (self fabricated parts/far from stock) 1990 MX-5 turbo (self fabricated parts/far from stock) |
03-16-2017, 12:35 PM | #13 |
Rep 52
How to diagnose:
After completing the oil change (so the oil filter cartridge would have a new O-ring), I "hosed" down the oil residue near the oil filter and the oil filter cap last night with cleaner. As soon as the engine was started, I started to see the car "bleeding" (weeping) oil from what appears to be the metal-metal junction of the oil filter assembly to the block. Too dark to video it so others can see. Looks like at a minimum, I need to replace the gasket.
03-16-2017, 03:22 PM | #14 | |
Need a 458
51
Rep 205
Theodore673.50 |
03-16-2017, 07:18 PM | #15 | |
Rep 122
03-18-2017, 10:46 AM | #16 |
Rep 52
Yikes! I posted in the other thread to see if cmtemauricio has further thoughts as I have been told anywhere from 3 to 8 hours to do it by local indy shops...
No room for an impact wrench to remove the damper bolts?
03-18-2017, 02:47 PM | #17 |
Rep 122
Yeah i could of done it in a day or so if I had all the right tools and no complications during the process. And yes I was thinking to use an impact wrench but I don't think clearance between those 4 bolts and ac radiator was enough for it to fit. It was one of the ideas to get it off including welding a nut in on top of it lol. You could try but u won't be able to hold it against bolts tight enough for it not to slip back due to clearance restriction that's if u were to find small enough impact to fit in there. Or u can take bumper off lol then u good. Honestly if I'd have to do it again I'd go straight to grinding it off and buying new bolts(just me thought).
03-20-2017, 04:56 PM | #18 | |
Rep 173
Nothing else will fit down there, then you just need to break it loose and it will come out by hand.
Mauricio Cardoso
03-20-2017, 05:45 PM | #19 | |
Rep 122
03-20-2017, 05:50 PM | #20 | ||
Rep 173
I was digging thru my tool box for a while until I came up with that solution. It worked perfectly though, 30k miles later and no more leaks still.
Mauricio Cardoso
03-20-2017, 06:01 PM | #21 |
Rep 86
UPDATE: Gave my car back to dealer since NYS law requires 30 day power train warranty I figured why not just have them do it. It has been 7 days of them with my car and have not gotten a single call back since the day I dropped it. Debating with myself if I should call them and see what's up. I say this because lemon law for used cars in NYS either 3 occasions in which the car was taken in for the same problem OR 15 days in which the dealer is in possession of your car due to a problem. So in a awkward possession.
03-21-2017, 04:49 AM | #22 | |
Rep 7,139
