03-18-2017, 03:46 PM | #1 |
Rep 122
Low engine temp while driving question. Pic included
I know I asked that question before and people told me it's normal but I'm pretty sure it's not. After oil filter housing replace and radiator removal and putting it back in this is the engine temp i get while driving normal speeds. If I were to let it idle in just sitting on a lot or pushing limits it stays in a middle or passes middle bar just barely. What could be the issue? Open thermostat? Well I replaced that. Also when temperature is below middle bar return hose is cold. As I mention in other post before that only about 6 liters of coolant/distilled water would make reservoir to the full mark. I let the engine run for a while before to let all the air out if it was could be aired but nothing changed. Any thoughts? Ideas? I know it's not normal. Also getting valve cover gasket leak idk if that's relevant to this issue. Happened few days after coolant flush.
03-18-2017, 03:48 PM | #2 | |
Rep 957
03-18-2017, 04:06 PM | #3 | |
Rep 2,362
Letting it idle = no air actively cooling, so it will obviously shoot up to the middle bar. The issue? You're thinking about it way too much |
03-18-2017, 04:40 PM | #4 |
///M
237
Rep 703
Mine idles like that during this time of year. Goes up a little bit if I push it. I live 20-30 minutes from Woodbrige.
Follow me on IG: dre.pt
03-18-2017, 04:43 PM | #5 |
Rep 2,526
Looks normal to me, but if you're not at the middle mark after 12 minutes of driving in above freezing temps, I would guess your thermostat needs replacing. Standing just below middle mark is fine, too.
03-18-2017, 06:22 PM | #6 |
Rep 3,141
Drives: 2014 M5 6MT
Exactly how mine behaves when I putt around..... you're fine.
Or you can drive it harder to push up those temps if you feel so inclined. The choice is yours.
2014 M5 6MT
03-18-2017, 08:11 PM | #8 |
Rep 488
Drives: 2011 E90 M3 6MT
Normal.
03-19-2017, 03:39 PM | #10 |
Retired Curmudgeon
3000
Rep 4,075
I don't think it's out of the range of acceptable.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
03-19-2017, 07:46 PM | #11 |
Rep 832
Who told you it wasn't fine? As above stated it is perfectly normal.
03-19-2017, 08:06 PM | #12 |
Rep 3,341
That's perfectly normal. All of my e92's sat just under 210 just putzing around. If driving in the mountains or doing some spirited back road driving they all got over 210 but cooled down quick.
BanjoPaterson160.50 |
03-19-2017, 08:55 PM | #13 |
Stop the hate, get a V8
3853
Rep 8,625
It's fine. The needle's margin of error is probably pretty big. As long as it's consistently around that middle mark, you are good to go.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
03-20-2017, 05:55 AM | #15 |
Rep 311
Totally normal.
During summer here when temps got to 40°C tried to get my temperature 3/4s of the way through heavy driving, albeit road driving. Got it a fraction past midway at best, and then driving leisurely it went back under. Whatever problems the E9x M3 may or may not have, keeping the oil cool doesn't appear to be one of them. Of course, this was limited to road use and not track use. |
03-20-2017, 04:26 PM | #16 |
Rep 378
Mine has been at about that point in normal use for a long time, though I do recall it being higher when the car was newer. Lately the analog needle reads 200ish and a digital guage will report 186 or so.
My bet is that your coolant mix was not 50/50 prior to the service. If you had more than half anti-freeze in the mix before, your cooling efficiency would be suboptimal. Now that you have refilled with a correct mix the efficiency has gone up because water cools better than coolant. That, or you used too much water on the refill! |
03-20-2017, 10:58 PM | #18 |
Rep 1,353
wish always runs at that temp (Floridian)
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
