03-24-2017, 08:59 AM | #1 |
Rep 144
iDrive 5.0 Bluetooth Audio
Just picked up my new 17 M3 a couple of days ago and just tried this morning to play stored music from my iPhone. With my 2015 535 this was very easy. With my M3 when I select iPhone from Media it defaults to playing Pandora. How do I switch from Pandora? My work around for now was to remove Pandoa from the phone.
2017 M3 Sakhir Orange/Sakhir Orange | Competition | Executive | Driver Assistance
03-24-2017, 10:30 AM | #2 | |
Rep 2,181
Update Pandora app at your iPhone... I used to have that bug showing up recently and it went away after Pandora updated its iPhone app.
03-25-2017, 05:03 PM | #3 |
Rep 144
I noticed today that it's not limited to Pandora. If you choose to connect your supported apps from your phone they will all appear under the media menu. Along with FM, AM, Satellite, iPhone, etc, you will see Pandora, Stitcher, Spotify, etc. The problem is that you can't go back and forth between the apps or to the music library on your phone without changing manually from the phone itself. Seems like that defeats the purpose.
I'm using an iPhone 7 with the most current OS.
03-27-2017, 07:14 PM | #4 | |
Rep 7
Was hoping I wasn't the only one experiencing this issue! I'm seeing the same with my iPhone 7+ and the Pandora app that lives on my phone and in the linked Connected Drive app in iDrive. I do listen to the music on my phone quite often but for some reason as soon as the Bluetooth link gets established, the connection wants to play Pandora on the phone - not even the iDrive media app. To get the connection to play stored music again, I have to physically start a song in my music library. I've turned off the "Use Cellular Data" option in the Pandora app. Don't use Pandora on phone much so I might just delete it as well but that seems to defeat the purpose of having the dedicated app too right? |
03-27-2017, 07:34 PM | #5 |
Rep 144
I've just unchecked the apps option in the manage mobile device settings for now. I would be nice if this worked as I'm sure they intended but having to pick up the phone every time does defeat the purpose. It's hard to believe these things are actually tested.
