New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      03-29-2017, 12:46 PM   #1
uluwatu06
Drives: 2021 F44 BMW M235i xDrive
Driver side storage tray - Faulty
Dear friends,
The latch for my storage tray is faulty. It is not able to hold the tray in the closed position. Hence, i have been driving with the tray open for quite a while. I know the latch is using a metal strip which holds the latch in locked position.
Anyone knows how to remove the entire tray so that i can work on it at home? Alternatively, any sites where i can purchase it?
Stealership here is asking me for $112 USD for the tray alone.
      03-29-2017, 02:20 PM   #2
cruisingdownthestreet
Drives: Z4
wait......there's a driver side storage?!?!
BRB
      03-29-2017, 03:36 PM   #3
paris1
Drives: 2013 35i Space Grey over Coral
BRB
Not on the SoCal version.
      03-29-2017, 04:11 PM   #4
uluwatu06
BRB
Dear Sir,
Yes, there is one. Enclosed is a picture which illustrates this better.
      03-29-2017, 05:01 PM   #5
Drives: Z4
argh....
      03-30-2017, 02:54 AM   #6
C.D.335xi
C.D.335xi's Avatar
Drives: 2013 X3
2014 Z4 35is  [0.00]
The exact same thing recently happened to me. I would also welcome any advice/suggestions for how to i) remove this tray and ii) repair it.
2014 Z4 35is Deep Sea Blue - Sold
2009 E92 335i X-Drive 6MT - Sold
      03-30-2017, 07:59 AM   #7
airmarc
Drives: '10 BMW Z4,'14 BMW X3, '17 X1
I dont think this option is on the US models..... jealous!
      03-30-2017, 02:47 PM   #8
uluwatu06
How have you live with it? Driving around with the tray open? Or you tape it close temporarily?
      03-31-2017, 02:11 AM   #9
C.D.335xi
C.D.335xi's Avatar
Drives: 2013 X3
2014 Z4 35is  [0.00]
I am able to close mine by pressing on the bottom of the part that is circled in red in your OP, which then causes the "button" on the outside of the door that is used to open the tray to re-appear (because the mechanism is broken, when you push on the button to open the tray, it "disappears" inside the tray door). I then use my index figure to apply a slight downward (i.e. towards the floor) pressure on the button to hold it in the closed position while closing the tray door at the same time. In my case, after doing this the door will stay closed. However, if I go over a large bump at high speed, for example, the door will sometimes open on its own.
I hope that you can understand my explanation and that you can get your door to close. It's much harder to explain the process in writing than it would be to demonstrate it in person (it wouldn't even be easy to film it as the space is so tight and the movements are literally fractions of an inch).
      03-31-2017, 11:21 AM   #10
uluwatu06
Dear C.D.335xi,
No worries, your explanation is very clear and I totally understand what you mean. Thank you.
It has been almost 2 weeks driving with the tray open and it is such a 'nuisance'. If i am not able to find a good solution to this, i may just decide to purchase a new piece.
      03-31-2017, 12:10 PM   #11
Bleen
Bleen's Avatar
Drives: 2012 BMW Z4 35i
Huh has anyone done a retrofit? Sounds like an interesting thing to do to the US cars that don't have this
      03-31-2017, 10:50 PM   #12
C.D.335xi
C.D.335xi's Avatar
Drives: 2013 X3
2014 Z4 35is  [0.00]
uluwatu06 if my method doesn't work for you, you may want to try putting some velcro tape, which you can buy for a few dollars, along the inside top edge of the door before spending more than $100 on a replacement from the dealer. That's what I'm going to try if my current method stops working.
      04-01-2017, 08:00 AM   #13
uluwatu06
Brilliant idea. Velcro shall be an option for now.
An old car anyway.
On a side note, are you MacGuyver?
      04-02-2017, 01:13 AM   #14
C.D.335xi
C.D.335xi's Avatar
Drives: 2013 X3
2014 Z4 35is  [0.00]
Based on the diagrams on realoem, it should be possible to do a retrofit. The only problem is that you would have to replace the whole bottom part of the dash. Although this little cubby is very useful (when the door works ), if BMW is asking more than $100 just for the door to this little cubby, I'm guessing this would be a really expensive project.
      04-02-2017, 01:16 AM   #15
C.D.335xi
C.D.335xi's Avatar
Drives: 2013 X3
2014 Z4 35is  [0.00]
No, but on rare occasions I can come up with useful ideas .
      04-02-2017, 01:21 PM   #16
distinctperson
Human
36
Drives: 2014 E89 35is
Has anyone retrofitted this to U.S cars ? This is a useful retrofit, it seems to me.
      04-03-2017, 09:23 AM   #17
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
What's up with the quilted cover on the shifter?
Does it get too hot to touch where you are?
      04-03-2017, 10:39 AM   #18
uluwatu06
Dear NQ,
Yes, it does get very hot if i were to park it without a shade during the summer months. At the peak last year, the temperature reading in the car did show 53 degrees Celsius. I believe that equates to 127.4 degrees Fahrenheit.
      04-03-2017, 10:53 AM   #19
NoQuarter
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
Dear NQ,
Yikes! Bet you have to watch out for those seats too!
Cheers!
      04-15-2017, 04:01 AM   #20
uluwatu06
Hi,
Just an update.
I have pasted a thin velcro strap on the inside of the storage space but it wont close snugly. I guess i will just proceed with the order of a new storage cover.
Thank you for all the advices and recommendations.
      04-17-2017, 03:57 AM   #21
C.D.335xi
C.D.335xi's Avatar
Drives: 2013 X3
2014 Z4 35is  [0.00]
Thanks for the update. Sorry to hear that the velcro trick didn't provide the solution that you were looking for.
      04-20-2017, 04:12 AM   #22
Mick70
Drives: Z4 sdrive35i (before: 23i)
My Z4's hatch between the seats (http://bit.ly/2oNDHBt) once was stuck and my stealer needed 2 months to get a new one (the complete back panel had to be replaced, what a design flaw!). I then broke the door open with a screwdriver, removed the damaged latch with a Dremel and used a small but strong neodymium ring magnet to hold the hatch in place until the new hatch came in. This was a very good solution, maybe even better than the factory solution.
Maybe this is also a solution for the small sorage tray door? I don't know if it's possible to hide the magnet and its metal counterpart so that you can still close the door completely.
zpost
