ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      04-24-2008, 07:59 PM   #1
BlackSapphireZ
Drives: 22 GLE 53 Coupe
Bi-Xenon retrofit
doing it now...will post pix later
2022 GLE 53 Coupe
      04-24-2008, 08:56 PM   #2
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Good luck
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      04-24-2008, 09:52 PM   #3
BlackSapphireZ
welp it's done. NO bulb out warning light or anything. Flash to pass works, i have BOTH high beams, walk me home function are all the same.
Halogen Headlight with projector in
pic without the projector
Halogen Cut Off
Bi-Xenon Cut off
Everything in place
Beam Pattern on Bi-Xenon LOW BEAM
High Beam(bi-xenon PLUS high beam) looks like a upside down U
Halogen VS Bi-Xenon NO difference in lens...little different cut off but hard to tell the difference
2022 GLE 53 Coupe
      04-24-2008, 11:16 PM   #4
nyczyang27
nyczyang27's Avatar
Drives: z4 3.0si / 328xi
Nice.
2007 Z4 3.0si Step/Premium/Xenon/HeatedSeats/AutoTop/M6Wheels
2007 328xi Step/Premium/Sport/Xenon
      04-25-2008, 08:39 AM   #5
Reach
gone baby gone
382
Drives: 2016 F80
So which projectors did you use? 06+ z4 oem?
Any wiring you'd like to post up for those of us who also might do such a thing?
      04-25-2008, 09:44 AM   #6
BlackSapphireZ
i only swapped out the projector. I had aftermarket HID's already then just used D2S to aftermarket ballast converter.
remember BROWN is negative any other color is positive on headlight.
2022 GLE 53 Coupe
      04-25-2008, 03:22 PM   #7
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Very cool, should move this over to DIY, I'm sure other people would be interested as well.
      04-26-2008, 08:54 PM   #8
Brucewonder
Brucewonder's Avatar
33
Drives: 2011 E92 M3 yea boi
sweet diy. love all of your mods. wish there was a way to put the angeleyes on our cars
2011.5 E92 ///M3 SSII/FR
      04-26-2008, 09:20 PM   #9
smidley
smidley's Avatar
24
Drives: BMW E60 M5
Good work, I did the same mod to mine. What brand did you use? I used EuroDezines. 8000k
      04-26-2008, 10:48 PM   #10
BlackSapphireZ
i used factory D2S 4300k bulbs... brightest
2022 GLE 53 Coupe
      04-27-2008, 09:39 AM   #11
Chuck I
Chuck I's Avatar
Drives: '03 Z4 + '07 ///M Roadster
Am I correct is assuming the reason you did this was to allow you to use the factory D2S bulbs? Does the bulb socket appear to be the main difference in the two projectors? I have the MTEC setup (I think that's what you had). Where did you get your aftermarket D2S converter? How did you get the cable out of the housing? I had to drill a hole through the cover for my MTECs.. Now you need to add the auto-leveling... that would be cool... Chuck
      04-27-2008, 10:19 AM   #12
BlackSapphireZ
I don't have M-tec...and I didn't spend $300 on it either
bulb holder is different...duh it's different for EVERY BULB.
D2S converter avail on ebay.
drilled a hole as well
auto level...not possible. No way. It requires sensors, motors, wiring, and etc to make it work. If i remember, someone tried to lower a car with auto level lights and it really messed it up because of that height difference
2022 GLE 53 Coupe
      04-27-2008, 03:55 PM   #13
smidley
smidley's Avatar
24
Drives: BMW E60 M5
Wow, I think this post jinxed me or something.... Now one of my headlights isn't working. The left side light works fine, but the right side doesn't turn on and it throws the bad bulb code in the dash. Looks like the bulb is fine, so I donno what the problem is. Could be a dead computer canceller, or a bad ballast maybe?
      01-18-2010, 01:49 AM   #14
andrewn80
Drives: 2004 Alpine White BMW Z4
Bringing up a post from the dead.
Nice retrofit. Question, you did not get any bulb out error codes? Smidley, did you ever get yours fixed? I'm thinking of buying the DDM Tuning 55w 6000k HID kit ($60) but I don't want error codes popping up.
http://www.ddmtuning.com/index.php?p...parent=85&pg=1
      01-19-2010, 03:54 PM   #15
smidley
smidley's Avatar
24
Drives: BMW E60 M5
Yea I got mine working. It turned out that one of the cables connecting these was bad.
      01-19-2010, 06:49 PM   #16
E86M
E86M's Avatar
Drives: E86 Z4 M Coupe
great job
      06-03-2014, 03:33 AM   #17
Beemerism
Drives: z4
Hello, I am also doing this retrofit.
To power the ballasts, did you get power from the wiring inside or outside the headlights?
I hooked up my ballasts to the low beam's wiring inside but they did not light up.
zpost
