04-04-2017, 09:14 AM | #1 |
Rep 119
Stripped drain plug
So I accidentally stripped the hex head of the the drain plug on my M3. Really trying not to take it to the dealer for a $300 oil change. Has anyone else done this by accident? How would you go about extracting the stripped drain plug?
Thanks in advance! |
04-04-2017, 10:04 AM | #2 |
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
Just out of curiosity, how are people doing this? Trying to jam a torx socket in there or something? I don't understand how these can be stripped.
You're going to need some sort of extraction bit.
04-04-2017, 10:07 AM | #3 |
Rep 119
No it was very easy to strip for me actually. I tried to drain it while still warm, put the 6mm hex in there and it seemed super soft and would just spin without turning the plug itself.
04-04-2017, 04:30 PM | #5 |
Rep 119
I did a search and most of the results were related to the threads in the oil pan being stripped and people most often use a time sert to repair it.
In my particular situation, the hex head of the drain plug is what is stripped. I was hoping someone on here might have a method of extracting the plug without having to drill it out. My ideas were using a screw/bolt extractor bit on it, or tapping a slightly larger torx bit into it with a screwdriver. |
04-04-2017, 11:36 PM | #8 |
Rep 12,739
i had a problem with the drain plug shrinking to the allen head when it cooled down and i had a hell of a a time getting it off.
Instagram; @roastbeefmike
04-05-2017, 11:09 AM | #9 |
Rep 769
The best solution I found was to use a small $5 chisel and hammer a little "slot" at an angle. Try to make your angle such that when you're hammering it is in the direction of unscrewing. I also tried screw extractors such as "speed out" but they didn't work for me.
04-05-2017, 11:28 AM | #10 |
Rep 614
04-10-2017, 05:04 PM | #11 |
Rep 119
Thanks for the help and input guys.
Ended up taking it to the dealer and having them do it (out of fear that I would mess it up more and the plug would have to be drilled out). If anyone has this problem in the future, the tech said he lightly tapped in a torx bit to extract it, just like someone else had suggested. |
