04-04-2017, 01:50 PM | #1 |
BimmerPost Supporting Vendor
2955
Rep 21,785
▀▄ eas | AST Coil Overs - Authorized Dealer - [Master Dealer]
Our newest addition to the EAS lineup is AST coil overs As a US importer we will carrying their full line up for all BMW's. PM today for fitment info and pricing AST 1-Way 4100 The 4100 Series shocks introduce high performance monotube technology at prices competitive with twin tube insert coilover kits. They include purpose built strut and shock bodies, shortened from stock lengths. All kits come with anodized aluminum adjusters that stay on the shock; no need to keep your pockets full of tools to make quick adjustments. Features - Monotube design shocks absorbers gives your car a better performance than the standard twin tube design, the gas pressure is separated by a floating piston and eliminates cavitation and airation within the oil chamber. - The 4100 series shocks allow rebound adjustment with one knob. - The adjust platform allows the user to adjust the ride height of your car. - AST suspension shock bodies are specially designed to keep maximum stroke, even with a lower ride height and are finished with a KTL coating for an extremely hardwearing finish. - Rebound Adjustable (“Singles”) - 22mm diameter shaft struts, non-inverted - Steel cylinder body shocks, non-inverted - Optional DDP piston (double digressive) - Optional spherical upper shock mount assemblies - Optional DLC Coated shafts - Re-buildable AST 1-Way 5100 Series shock absorbers The 5100 Series shock absorbers utilise inverted / upside down technology. The inverted design is race proven technology and produces an extremley strong damper, providing better suspension geometry under heavy lateral and braking loads as seen in a road and track environment. The 5100 Series shock absorbers give your car a better performance than the standard twin tube design. With the 5100 Series suspension you can adjust rebound with one knob. The adjust platform allows you to adjust the ride height of your car. AST suspension shock bodies are specially designed to keep maximum stroke, even with a lower ride height. Features: High-end, track ready suspension that is totally streetable Rebound Adjustable (“Singles”), without reservoir 44.5mm diameter shaft struts, Inverted New low friction seal on all AST dampers Rubber bushings for “eye” shock mounts Optional Spherical lower “eye” shock mounts Optional spherical upper shock mount assemblies Optional DLC Coated shafts Optional DDP piston (double digressive) AST 2-Way 5200 The 5200 Series are 2-way adjustable shock absorbers which are based upon competition 3-way adjustable shock absorbers. The 5200 shock absorbers are adjustable in compression and rebound. The design of the compression adjuster is an evolution of the compression adjuster we provided for the American Grand-Am series for the last few years. The 5200 shock absorbers were designed to achieve a quick and easy set up, allowing separate adjustment of compression and rebound. In the 5200 Series AST uses an external canister. Throughout testing and competitions, the 5200 has been praised for its performance and capabilities, surpassing other major, more expensive brands and setting a new standard of 2 way damper. Its no surprise that the 5200 is fast becoming a favorite damper amongst race teams and track day enthusiasts world wide. Features: - High end, track ready suspension that is totally streetable - Fully upgradeable to 5300 spec - Rebound and Compression Adjustable (‘Doubles’), with a remote reservoir - Remote reservoirs allow additional travel and heat dissipation - 44.5mm diameter shaft struts, Inverted - New low friction seal on all AST dampers - Spherical lower ‘’eye’’ shock mounts - Reservoir with hose or piggyback - Spherical upper shock mount assemblies - Synthetic hydraulic fluid - Optional DLC Coated shafts - Optional DDP piston (double digressive) AST 3-Way 5300 For the best performance on the track, AST Suspension designed the Competition 3-way adjustable series. The 5300 Series shock absorbers are rebound adjustable in 12 positions on the strut. The highspeed compression is adjustable in 12 positions and the lowspeed compression is adjustable in 14 positions. Both compression adjustments are made using an external canister. All adjusters work completely independent. Many years of technical knowledge, testing and experience has been refined, fettled and brought together to create a perfect balance between the choice of springs and the corresponding damping characteristics. This makes it a versatile product for every customer. The 5300 series shock absorbers are the best solution for every race team. Once installed te shock absorbers are easy to setup, highly reliable and require low maintenance during the season because of the high grade of materials used. All of this together makes the 5300 series shock absorbers a championship winning damper, over and over again. The AST 5300 Suspension is worldwide renowned for its performance at every level. Features: - High end, track ready suspension - Rebound, Low & Hi Speed Compression Adjustable (‘Triples’), with a remote reservoir - Remote reservoirs allow additional travel and heat dissipation - 44.5mm diameter shaft struts, Inverted - New low friction seal on all AST dampers - Spherical lower ‘’eye’’ shock mounts - Reservoir with hose or piggyback - Spherical upper shock mount assemblies - Synthetic hydraulic fluid - Optional DLC Coated shafts - Optional DDP piston (double digressive). Models Supported 2015+ BMW F80 M3 2015+ BMW F82 M4 Ordering: Phone: You can reach us directly by calling 866.669.0705 x31 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM to 2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 02-06-2019 at 05:00 PM.. |
04-06-2017, 05:59 PM | #2 |
2955
Rep 21,785
AST 5100's being installed @ EAS
PM today to get yours!
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
04-18-2017, 04:49 PM | #3 |
2955
Rep 21,785
Thanks for the inquiries
AST coil overs setups in stock and ready to go PM today for options and details
05-01-2017, 05:17 PM | #4 |
2955
Rep 21,785
EAS your #1 source for AST coil overs PM today for options and details
06-27-2017, 05:47 PM | #5 |
2955
Rep 21,785
AST 5200's featuring remote reservoirs
PM today for applications and details
08-02-2017, 04:53 PM | #6 |
2955
Rep 21,785
PM today for details and pricing
08-23-2017, 11:43 AM | #7 |
2955
Rep 21,785
AST 5100 series
In Stock and ready to ship PM today to get yours
11-17-2017, 06:18 PM | #8 |
8312
Rep 18,880
EAS is your #1 AST dealer, call to get your AST coilovers today!
07-18-2018, 04:00 PM | #9 |
2955
Rep 21,785
Enjoy Moton/AST Summer sale
10% off PM for details and pricing
07-24-2018, 05:42 PM | #10 |
2955
Rep 21,785
Enjoy 10% off on AST suspension sale
Take advantage while you can PM for pricing and details
08-01-2018, 05:29 PM | #11 |
2955
Rep 21,785
Another set of AST's installed @ EAS
Save yourself 10% while you can PM for details and pricing
12-05-2018, 04:38 PM | #12 |
2955
Rep 21,785
AST coil overs ready to ship PM today for options and details
12-12-2018, 05:04 PM | #13 |
2955
Rep 21,785
Save yourself 10% on AST coil overs PM for details and pricing
12-17-2018, 05:12 PM | #14 |
2955
Rep 21,785
Save 10% while you can
AST kits ready to go PM today for details
12-28-2018, 01:55 PM | #15 |
2955
Rep 21,785
Hurry time is running out on AST winter sale
01-14-2019, 03:53 PM | #16 |
2955
Rep 21,785
02-06-2019, 04:59 PM | #17 |
2955
Rep 21,785
EAS your #1 dealer for ASt/Moton
02-11-2019, 05:45 PM | #18 |
2955
Rep 21,785
AST 4100 in stock and ready to go
02-20-2019, 05:43 PM | #19 |
2955
Rep 21,785
EAS your #1 AST/Moton dealer
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 02-20-2019 at 06:07 PM.. |
03-28-2019, 06:34 PM | #20 |
2955
Rep 21,785
04-08-2019, 06:42 PM | #21 |
2955
Rep 21,785
04-17-2019, 02:52 PM | #22 |
2955
Rep 21,785
AST 5100 coil over sets in stock and ready to ship
