04-19-2017, 12:33 AM | #1 |
Rep 182
Data logging on S65
Has anybody done any? It does not seem nearly as popular on this motor as on an N54 for example.
I am looking at Test0 and BMW Logger. I am primarily wanting to make sure that my air/fuel is right. What else do I need to watch for on a VF650 supercharged motor with the E85 Flex fuel kit? Any input, guidance would is appreciated! |
04-19-2017, 10:32 AM | #2 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
have you considered an awron gauge or at the very least the p3?
since you are using e85 i'd also look at fuel psi?
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
04-19-2017, 01:23 PM | #3 |
Rep 162
Most of the OBD2 modules can log the basic DME parameters, but none can access the direct DME BUS for high-rate sampling as those require specialty tools. I'm using the BT tool, and best I can get is about 7-8 data points per second when logging 20 parameters, which is 'good enough' for monitoring. You can increase resolution of sampling by removing logged parameters.
Bavarian Technic has access to a long list of DME parameters, which is why I chose it. I dump my .csv files into MegaLogViewer. Makes reviewing and overlaying logs easy. Logs look like this in MegaLogViewer:
2009 E90 M3 DCT
IMG1126.50 |
04-20-2017, 12:45 AM | #4 | ||
Rep 182
04-20-2017, 08:52 AM | #5 | |
Rep 162
So far it has been a great investment. The only negative is that it currently does not support battery reset, which some tools half the price have the capability of doing. I'm not sure what other OBD2 devices have for DME parameters, but the BT has a very long list of available parameters. Attached is the list in BT.
2009 E90 M3 DCT
10-23-2019, 03:05 PM | #7 |
Rep 141
I purchased a CARLY unit and it is junk/borderline scam imo. They lure u in for an affordable unit, then charge you for every feature, and lock it to a particular VIN # (for which some were free for all vehicles at first but changed later on!).
Anyhow...BT looks promising, Anyone else know what tools are available for us to use? and how about tuning capabilities? anybody know how to access the spark and fuel maps? Thanks |
