05-02-2017, 10:09 AM | #1 |
Rep 264
Help Please! Muffler Delete but that Drone
First…need to eat some crow here. Upstate650…you were right so no need to say “I told you so” haha. The drone is bad…very bad.
Here’s the story: I had my mufflers deleted yesterday and had the tips installed. First and foremost, I wanted to achieve the look in the picture below. I am incredibly happy with how awesome the tips look coming through the M6 / v-style diffuser. The muffler shop here in Denver (House of Mufflers) did an absolutely fantastic job. I also had heard some clips on youtube of the exhaust sound and similarly, my exhaust note (when outside the car!) sounds absolutely fantastic, very exotic. But the drone is really bad. If I could somehow figure out a way to achieve the look I want, keep the sound, and reduce the drone, I would be happy. Unfortunately, when in comfort mode, the car’s aims to run the RPMs up slowly to 2k and then shift. This slow generation of RPM build-up causes massive drone. When in sport mode, the drone is not bad when accelerating. However, when coasting around 40 or so MPH, the RPMs are just over 2k and again, the drone is horrible. Keep in mind I have a convertible so I am guessing it is a little worse for the F12 owners. I have to do something. Going back to my original mufflers is possible but is not really an option. Quite frankly I can’t achieve the look of the quad burnt tips (these are 3.5” but I would love 4.0”) by purchasing single burnt tips for the 650 muffler (the dual outlets will only handle 3.0” round tips). I called the muffler shop up and he mentioned possibly adding a new muffler onto the deleted section that only has a single outlet that can accommodate the tips I purchased. He was mentioning trying out magnaflow and that it may reduce drone, there will likely still be some. I am still very new to the N63TU engine and BMWs in general as I want to ask the experts out there…Do any of you guys have any advice? What about an M5 or M6 muffler? I know Megan has a setup but I just don’t love the sound and quite frankly, I like the tips I have so much more. I want to keep this somewhat cost friendly but I just took a $400 gamble and it failed pretty miserably. Goals remain as follows and in in priority: (1) keep burnt 3.5” or 4.0” dual tips (ideally the same ones I have), (2) no drone, (3) better exhaust sound. Any help is greatly appreciated. Thanks in advance! |
05-02-2017, 11:59 AM | #2 |
Rep 553
Sorry to hear what happened. It sucks to throw cash down the drain, I've been there. It does look very cool though.
Well, muffler sound is sort of like wheel sizes. You get to a point where it gives diminishing returns. Loud will give you drone or an ear ache after awhile. There's really no way around it. Even with $3k Meisterschaft mufflers, you'll get drone. Sort of like very large wheels will eventually give you a bad ride. For sound, you'll have to compromise to get the look. IMO, your options: 1. Keep straight pipe but have muffler shop weld on 'J' pipes to diffuse the drone. It'll still be loud, drone 'may' minimize but there's no guarantee. You may end up throwing more cash down the drain. 2. Pick up a set of Megan M5/M6 for $500 and be done with it. 3. Pick up a set of used OE M5/M6 mufflers and you have the option of changing out the tips to burnt tips. If you can find competition ones, you'll get a much better sound. With options 2 and 3, the sound will definitely not be as loud and aggressive as what you currently have but there are ways to sort of make it meaner. For M5/M6 mufflers, you can install an exhaustmeister and remotely open the valves during throttle and have it closed at 1500-2k rpm. If that's not loud enough, you can go the route of getting a muffler bypass system and remotely open the bypass valve so it'll sound like your straight pipe when you want. I believe a 650 will require 2 bypass systems. You can also install x-pipes and downpipes to achieve a more aggressive sound but again, that's more money. Good luck. |
MSUGOGRN65.50 |
05-02-2017, 12:24 PM | #3 |
Rep 1,715
Drives: 2014 650xi Gran Coupe Msport
Do you have to have burnt tips?
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
05-02-2017, 01:45 PM | #4 |
Rep 264
Really appreciate the replies from both you guys!
In regard to the question on whether I need to have blue tips, I really don't "need" anything haha . I am just really happy to have this car and I am so pleasantly surprised with how these mods are coming along. Regardless, I had a vision in my mind and now that I have seen that vision come reality, I really like how it turned out. I wish I could have found some 4" tips but alas, 4" with staggered fitment is not available. In a nutshell...yes, I still really want the burnt blue tips. I could be convinced to go chrome but not black or CF since I think they would just get lost. As far as the recommendations from ndinh, I have been heavily considering the M5/M6 route. Would both work for my car? Those utilize slip on tips right? Or...I am guessing I could have the shop weld on some burnt blue tips...even creating a staggered look? Would those mufflers use the valves to improve drone? Sorry for the million questions...just so much to learn. Can't believe exhaust could be this difficult! |
05-02-2017, 01:56 PM | #5 | |
Rep 553
05-02-2017, 02:15 PM | #6 |
Rep 264
Damn...I didn't realize you had the M mufflers on your car. This definitely sounds like an option. I have heard about exhaustmeister too so will look into that. Are you able to control all valves with your exhaustmeister or are you manually doing that?
Also, do you think you could have gone 4" tips or would that put them too close to each other? I was looking at pics of your ride and it would seem that 4" may be too big. |
05-02-2017, 02:39 PM | #7 | |
Rep 1,715
All aftermarket exhaust will have some drone, except maybe the meistershaft valved systems. You could buy that and use whatever tips you want. I'm not sure if they offer blue tips, but the meistershaft is pricey, like 5K for a new valved system There is no perfect option for what you are trying to do, anything and everything will be a compromise of sorts. Your top 2 priorities - 4" blue tips and no drone - may not be feasible. Unless you are willing to spring for the meistershaft
05-02-2017, 02:55 PM | #8 |
Rep 264
You guys are frickn wealth of knowledge. So couple follow up questions.
1. You had mentioned all aftermarket systems have drone but would that be inclusive of the m6/m5 set up? Or since they have the valves they would have almost no drone as well? I am thinking that I already like the 3.5" tips so this is something I could definitely make work! 2. Is Meisterschaft low drone because of the valve set up? So basically nothing with the valves will reduce drone? These guys make a quad 4" set up with blue tips. Even though their price is much better than Akrapovic, it's still sadly out of my range. Just wish they did an axle back. You guys ever heard of this company? http://www.fi-exhaust.com/product/bmw/f12-f13_650i.html Lastly...any thoughts on reasonable prices to pay for an m6/m5 exhaust set up? Ideally I would just do axle back right? Or should I go full cat back? Last edited by MSUGOGRN; 05-02-2017 at 03:07 PM.. |
05-02-2017, 03:16 PM | #9 | |
Rep 1,715
05-02-2017, 03:18 PM | #10 | |
Rep 553
Meisterschaft and other valve setups are low drone because you can close the valves while at cruising speeds. Never heard of fi-exhaust but it looks pretty awesome, very similar to Armytrix. |
05-02-2017, 03:26 PM | #11 |
Rep 264
Good to know guys. I will keep a look out on the classifieds section in both the 5 and 6 forums to see if anybody is selling one. Someone has one right now in AZ but its the full system. In the meantime, I will just have to enjoy the wonderful exhaust tone and ignore the drone haha.
05-02-2017, 03:33 PM | #12 |
Rep 435
Try to unplug the asd, it should reduce the drone significantly
Current Cars:
2017 GT350 2018 Mineral White M3 2015 ML63 AMG |
05-02-2017, 03:35 PM | #13 | |
Rep 264
Edit: Never mind. Though I can't find a thread on our forum discussing this, I did find post 45 on the thread/forum in the link below and this is definitely worth a shot. Can't believe that my stereo may be amplifying the drone! Last edited by MSUGOGRN; 05-02-2017 at 03:59 PM.. |
Oliver Queen202.50 |
05-02-2017, 11:41 PM | #14 |
Rep 1,715
Where did you find instructions on how to deactivate the ASD without coding? I thought you had to do it through coding?
05-03-2017, 12:07 AM | #15 |
Rep 264
Just got back from the garage. Tore apart the inside of my trunk on the driver's side where the module is supposed to be. Couldn't find anything that remotely resembled the same part that the F10 guys have. My local dealership offered me a "deal" to code it off for only $130. At this point I may give it a shot. Before that I am going to ask the M6 and our forums if anybody has ever disconnected the ASD on an F12.
05-03-2017, 06:02 AM | #16 |
Rep 1,715
You can get get the full coding treatment from one of the online guys for close to that price.
05-03-2017, 07:06 AM | #17 |
Rep 264
Coding is something I still need to research more about. I really would like to do it myself but I just have not had the time to do all the research and understand how it is done. Would you be able to point me in the direction of a thread or a poster who could help?
05-03-2017, 07:59 AM | #18 | |
Rep 1,715
05-03-2017, 09:34 AM | #19 |
Rep 264
Well for now, I am looking for a quick fix so ideally someone who could help me out remotely. I assume you probably do your own coding but just in case, have you worked with anybody that you recommend? Maybe you can PM me their information?
05-03-2017, 10:18 AM | #20 | |
Rep 1,715
I'm not aware of a specific coding thread for the 6 series - I think everyone uses the 5 series coding thread without issue.
05-03-2017, 10:28 AM | #21 | |
Rep 264
After much research I am pretty certain that I don't have active sound in my car. I think it is only in the M6. Is there something else you have seen to the contrary? I also took my trunk apart last night looking for this module on my driver side in the trunk. As you can see there is nothing there resembling this module. Thoughts? |
05-03-2017, 01:25 PM | #22 | |
Rep 264
