BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      05-17-2017, 11:31 PM   #1
johnnydg
Drives: e92 m3
Vibration under load in chassis and pedals
Hi all, I have a vibration under load in the chassis and pedal and shifter. Nothing really in the steering wheel. I just put my OEM exhaust back on except for the axle back Eisenmann race exhaust. Nothing is touching anywhere under the car. I have been working on this for weeks and thought it was an exhaust issue, now with the OEM exhaust back on what else could this be?
Also, when I put my clutch in, the vibration for the most part goes away. Then when I release the clutch it comes back. I assumed this had to do with exhaust pressure causing a vibration in the chassis but obviously that isn't it.
This is on my 2011 e92 m3 supercharged with 37k miles, and only does it while I am moving, not at idle
      05-18-2017, 12:32 AM   #2
johnnydg
Drives: e92 m3
A friend suggested the Guibo joint/flex joint and transmission mounts. And to check the driveshaft?
      05-18-2017, 03:48 PM   #3
fwrigley
Drives: 2018 BMW M3cs
Based on the symptoms could it be the throw out bearing?
m3post
