05-27-2017, 02:52 PM | #1 |
Rep 1,489
BMW M3 car safety reference and issues
Interesting link. Maybe this should go into another section.
http://www.carsafetyreference.com/bmw-m3/ |
05-27-2017, 06:05 PM | #3 |
Rep 1,489
05-30-2017, 05:54 PM | #4 |
just another M3
514
Rep 1,152
My 08 is nothing but a champ hardly any issue, never towed it never stopped running, but I maintained it well. But abused it even more. 105k miles 35+ track days.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
6ixSpd6034.50 |
05-30-2017, 07:30 PM | #5 |
Stop the hate, get a V8
3853
Rep 8,625
That is a really janky website. Also, my thought on it as a whole: [citation needed].
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
05-31-2017, 01:49 PM | #8 | |
just another M3
514
Rep 1,152
here are some large maintenance items I did that might be considered expensive but saved money doing it my self Rod bearing =$850 Water pump and thermostat = $435 (competition water pump) TVA = $ 450 (new brass gear) Driveshaft = $300 all 4 Wheel bearing = $450
05-31-2017, 02:02 PM | #9 |
Rep 1,489
VAC Rod Bearings $3200.00
Suspension springs (H&R) Bilstein Heavy Duty EDC dampers Leaking valve cover gasket Control arms Wheel bearings $5000.00 1 Throttle Actuator purchased + 2 Sets of brass gears (1 failed) ~ 1900.00 Thermostat Sensor + Thermostat + Water Pump + Pulley + Hoses = $960.00 (for genuine BMW branded doh!) Did the labor my self but original problem not fixed. Next will be a visit to the dealer and hope the cooling issue isn't the the evap $$$$. Other than the above. I have driven the car from Oregon to NJ and continue to rack miles like crazy. I enjoy driving it. I also have the Dinan ECU tune which has made it a real joy to drive! No kidding! Last edited by L4ces; 05-31-2017 at 02:05 PM.. Reason: Reiterate that I enjoy driving this car! |
05-31-2017, 02:14 PM | #10 |
3853
Rep 8,625
But this data isn't being cited or qualified in a meaningful way. The overall quality and trustworthiness of it is extremely low, in my opinion.
05-31-2017, 02:33 PM | #11 | |
Rep 1,489
This is what I copied from one of the paragraphs: "Our website is a vast database of information about the more practical use of cars, all in one place." I went back to the page I searched the page to identify who is behind the site. I found no link, nothing credible, no mention of a source. Truthfully, it could be someone's project to scrape the web for such information to auto generate what appears to be researched information (in a effort to create a portal for eyeballs etc). |
06-01-2017, 12:57 PM | #12 |
3853
Rep 8,625
I am also skeptical of anything that relies on self-reporting. Why? Typically, the only people who speak up are the ones at either extreme of the ownership spectrum. If you want to form your own opinion, you must consult a variety of different sources and qualify their data to the best of your abilities. No one is 100% unbiased, but you can weed out the obviously low-quality data.
Someone who loves their car and wants to tell everyone else about how great it is will, of course, report a perfect ownership experience, rate everything 10/10, and ignore/downplay any problems. Conversely, the person who hates their car will do nothing but exaggerate and dwell on the problems, even minor ones. They will rate everything 0/10 and never mention the redeeming qualities. You will know what I mean if you look through any of these rod bearing or throttle actuator threads. A very vocal minority makes the issue sound bigger than it is. Only people who had the problem speak up; you don't have thousands of people saying "my car is fine". The other issue I have encountered with these types of sites or companies is how they classify various problems. For example, years ago, when Ford introduced one of their new infotainment systems, a lot of owners found it difficult to use. Nothing was broken, but the interface was just a bit confusing. A lot of owners went back to the service departments for assistance and each visit got logged as an electronics issue. As a result, Ford's reliability as reported by various companies (Consumer Reports, etc) looked HORRIBLE in the "electrical" area. This was very misleading as nothing was broken nor were the cars any less reliable than the previous year. The reporting bodies didn't explain this, they just put the blemish on there since that's what the data showed. Only an astute reader would have known to go deeper. A person casually perusing the reliability reports would have run away from the Fords.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 06-01-2017 at 01:07 PM.. |
06-01-2017, 10:38 PM | #13 | |
Rep 1,489
