      07-18-2017, 07:56 PM   #1
MCShred
Getting Risky ;)
MCShred's Avatar
Drives: 2010 128i 6MT Space Grey
MCShred "Build" Thread
Hey Guys, Im fairly new to the forum but have been quickly putting together my 1er through the help of your posts. My 2010 128i (N51) Space Grey came with the Sport Package, 6-Speed Manual, Black Leather Interior, and Xenons. I have already installed 12mm BMS Spacers all around, CDV Delete, Active Autowerke Exhaust, and AFE Stage 2 CAI. I have Active Autowerke Headers currently getting coated at Swain Tech... I have plans to do an extremely clean build all around. I plan on doing suspension,performance brakes, and wheels ASAP after I get the headers installed and the car all tuned up! Let me know what you guys think
      07-19-2017, 01:42 AM   #2
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Grey manual sport 128i? I'm gonna be following this like a hawk.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      07-19-2017, 07:12 AM   #3
Taskmaster
Japan
2470
Drives: M235i 6MT / E92 328 Msport 6MT
Any goals for the build? Plans for parts - tune? Coilover? Brake pads?
      07-19-2017, 08:58 AM   #4
MCShred
Getting Risky ;)
MCShred's Avatar
I did order the AA tune with the headers to try out first, I do have access to a dyno and will be posting up the numbers after the install and tune. Still deciding between KW V3's or Ohlins R&T for suspension. I want to do a bigger brake set up but still deciding on what to get
      07-19-2017, 09:01 AM   #5
MCShred
Getting Risky ;)
MCShred's Avatar
you have good taste
      07-19-2017, 12:07 PM   #6
Jrfly9
Drives: 2011 128i Msport
In for those dyno numbers!
I am N51 with similar mods and am interested to see what you put down
      07-19-2017, 01:17 PM   #7
Taskmaster
Japan
2470
Are you building it for any classes like STX? If not, a BPC tune with the ALFA N option and a set of Valvetronic Rocker arms is a quick way to get extra power. (ALFA N is not legal with STX, nor is the rocker arms)
Any reason why you chose the V3 or R&Ts? I thought the R&T's spring rate was too low, and the V3s have Progressive springs?
Phil@BPC467.00
      07-19-2017, 01:57 PM   #8
MCShred
Getting Risky ;)
MCShred's Avatar
Building as a fun summer project at the moment. Could you give me more info about the ALFA N option for the BPC tune and where I could find the Valvetronic Rocker Arms?
I always here nothing but good stuff about the R&Ts. Still have time to decide about suspension, still doing more research. What would you suggest for spirited driving and an occasional track setting?
      07-19-2017, 02:23 PM   #9
asbrr
Drives: 2014 335ix M-Sport
The suspension "spectrum" is quite huge....usually people start with a budget, do you have one in mind? The fact that you have Ohlins on your list tells me you have decent cash to spend on it. They are good, but many folks here opt to swap the springs out on them for ones that are better suited to the E82 (the Ohlins kit is basically a 3 series kit that fits on E82s).
You should talk to Harold @ HPA, he has a ton of experience and can help walk you through options, and they are a good vendor from everything I've read/heard (I'm not affiliated in any way, have never even bought anything from them).
TC Kline has some nice stuff for these cars also...like I said, tons of options.
Taskmaster2470.00
      07-19-2017, 02:32 PM   #10
desertman123
Drives: '08 128i
http://www.e90post.com/forums/showthread.php?t=1329840
Valvetronic lift mod. Good for squeezing that very last bit of performance out.
Also since you're manual, consider the auto diff 3.73 swap (or even a regeared LSD)
      07-19-2017, 02:49 PM   #11
Taskmaster
Japan
2470
Bob@BPC John@BPC Can explain better, but it allows you to run with a iat sensor in place of the maf - simplifies tuning and has the potential for more power depending on intake types.
The valvetronic lift mod just adds more effective lift to the intake cam at 80% throttle or more - but you need a tune. The .5mm increase was good for 8whp - I have the 1MM
http://www.e90post.com/forums/showpo...&postcount=240
And I second the opinion of calling someone experienced on picking a suspension - TCKline, Ground Control, or just talk to Harold at HPA and they will point you in the right direction.
Phil@BPC467.00
      07-19-2017, 07:25 PM   #12
MCShred
Getting Risky ;)
MCShred's Avatar
Awesome I'll have to give them a call!
      07-19-2017, 07:26 PM   #13
MCShred
Getting Risky ;)
MCShred's Avatar
Since I'm doing the AA tune first would it be beneficial to do this now or later on with a BPC tune?
      07-20-2017, 01:00 AM   #14
desertman123
Drives: '08 128i
I'd do it later on with BPC. Seems like they know how to handle it.
I can't remember off the top of my head, but were any dyno runs for purely NA made for the valvetronic lift mod? Like stock motor, then motor with the lift/appropriate tune?
Phil@BPC467.00
      07-20-2017, 01:27 PM   #15
Taskmaster
Japan
2470
AA doesn't have a tune for those. I sent BPC my personal set of the .5mm shims to make a tune from it, then they had a second 1mm set to use (from the supplier) to test on their turbo N52.
Without knowing what to modify, or not tuning it at all, they won't work.
      12-27-2017, 08:53 PM   #16
MCShred
Getting Risky ;)
MCShred's Avatar
UPDATE: Headers are in place, replaced the water pump and thermostat while underneath the car...The headers sound great but haven't had a chance to drive with it yet...Having some issues with the idle of the car after uploading the tune and resetting the adaptations , it's surging like crazy Plan is to change the oil and put some miles on her and see if anything changes!
      12-27-2017, 08:57 PM   #17
MCShred
Getting Risky ;)
MCShred's Avatar
As a side note I had some wheels refinished and re-drilled by Jordan over at Sensei6.... insane quality... Cannot wait to get the suspension delt with within the next month or so!
      12-28-2017, 01:12 PM   #18
Taskmaster
Japan
2470
Reset the adaptation again. Also, what are you doing for suspension?
      12-28-2017, 03:06 PM   #19
MCShred
Getting Risky ;)
MCShred's Avatar
I know originally I was leaning towards the KWs or the Ohlins but I think I'm going to go with the Bilstien PSS10 Coilover with M3 LCA upgrades and Ground Control Camber Plates. Reseting the adaptations right now! Logged about 60~ miles today, very impressed so far with the AA Headers + Tune..
      03-21-2018, 11:02 PM   #20
MCShred
Getting Risky ;)
MCShred's Avatar
Tiny update: Aero bumper and side skirts along with other goodies are currently getting painted... Just received pictures from the powdercoater of the Calipers
Rmtt8222.00
croy0.00
      03-25-2018, 06:50 PM   #21
Eins Suchtig
Eins Suchtig's Avatar
61
Drives: 2011 SGM 128i MSport
Nice!!!!
MCShred99.00
      03-27-2018, 02:24 PM   #22
SmallDave
Drives: 335d Sport Package
Awesome car! Looking forward to seeing the progress.
MCShred99.00
1addicts
