07-28-2017, 08:13 PM | #1 |
Rep 238
Eisenmann Race Exhaust Owners
Looking in getting in. Does this come with a working valve actuator? Meaning it uses the existing vacuum tubes for the flaps.
Is there a big difference in sound when two vs all 4 valves open? Thanks |
07-31-2017, 10:46 PM | #2 |
Rep 1,715
Drives: 2014 650xi Gran Coupe Msport
No valves on eisenmann race
08-01-2017, 01:24 AM | #4 |
Rep 804
I'm about to install an Eisenmann Sport with valves on my M6, no resonators, remote valve control, BMS intake. Should sound good with the valves open, and no drone when closed.
08-01-2017, 03:56 PM | #5 | |
Rep 443
I am looking at the exact same set-up. |
08-01-2017, 04:02 PM | #6 |
Rep 804
Will do! I should have the exhaust by the end of this week, installed next week most likely. Resonators are already off and the exhaust meister valve control is installed and working off the homelink buttons, it's so cool!
08-01-2017, 07:47 PM | #7 |
Rep 804
08-01-2017, 11:09 PM | #8 |
Rep 523
I had just a few days w my E-sport, no resonators in the midpipe and flaps open. It sounds just a little louder than the CP exhaust I had with some drone in the 1800-1900 rpm zone. I'm not sure if the resonators would make a difference. I am putting catless DPs on in the next day or so and can post videos then. I had the shop wire my valves open.
08-02-2017, 12:08 AM | #9 | |
Rep 804
08-02-2017, 05:54 PM | #11 |
Rep 523
Idk if it's just me that's a little more sensitive to drone, but I noticed drone even on my stock CP setup w flaps always open. The CP exhaust may be made by Akra, but the M-Perf exhaust made by Akra is an equal comparison to the Akra Ti exhaust. Basically, non-CP < CP < Akra Ti/MPE < E-sport < E-race.
The drone isn't any more pronounced w the E-sport. The overall exhaust sound is louder, but it wasn't like "whoa this is amazing" when I put it on. Versus a non-CP car, I think you will be pleased going to this setup. I knew I was getting catless DPs, so I didn't want to go w the E-race. I was afraid it might be too loud/ricey. |
08-02-2017, 06:04 PM | #12 | |
Rep 804
10-31-2017, 11:46 AM | #15 |
Rep 84
04-24-2018, 03:48 PM | #16 | |
Rep 101
Morten |
04-24-2018, 04:02 PM | #17 |
Rep 804
It makes no difference either way. A decent muffler shop can cut off the resonators and weld in a pair of stainless pipes, the section is straight so it should be easy and cheap as there are no complicated bends or anything. The Eisenmann center section will make no difference in sound or performance compared to what I just explained so it is on you to spend your money how you like.
04-26-2018, 12:28 PM | #18 |
Super Member
129
Rep 344
I have the E-Race exhaust, with a custom X-Pipe and res delete with AA Catless DP's. In sport plus its loud and crackles but in efficient its nice and quite.
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust |
04-26-2018, 12:54 PM | #19 |
Rep 101
04-26-2018, 01:00 PM | #20 | |
Rep 101
04-26-2018, 02:52 PM | #21 |
Rep 804
