08-14-2017, 06:40 PM | #1 |
Rep 251
UPDATE: lost programming on the 8 programmable buttons
I just noticed that since this morning I lost the programming on the 8 buttons that can be programmed to various functions on the vehicle. The seat position and radio stations remained intact, just the programming behind the buttons seems to be gone.
Has anyone experience that before? Any clues as to what may have caused this? I reprogrammed some of the buttons and will continue to monitor this.
2018 M3
2017 X5 35d xdrive Msport Sold: 2014 X5 35i xdrive Msport Last edited by ramsal; 09-16-2017 at 05:27 PM.. |
08-14-2017, 07:33 PM | #2 |
Rep 256
Drives: '17 F15 MSport
Check to make sure the proper driver profile is selected...
08-14-2017, 08:22 PM | #3 |
Rep 251
Just went back to the vehicle and the all of the presets are gone again
Confirmed that the profile is fine. Will have to check this with my wife's key.
2018 M3
2017 X5 35d xdrive Msport Sold: 2014 X5 35i xdrive Msport |
08-14-2017, 09:39 PM | #4 |
Rep 256
Sorry, out of suggestions. That was the issue the one time I had a similar problem after service.
08-15-2017, 09:25 AM | #5 |
Rep 251
checked with my wife's key and her profile appears to be fine, settings are retained.
I reset my profile and programmed a couple of the buttons. Will check in a few minutes to see if the reset fixed it.
2018 M3
2017 X5 35d xdrive Msport Sold: 2014 X5 35i xdrive Msport Last edited by ramsal; 08-15-2017 at 09:32 AM.. |
08-15-2017, 09:35 PM | #7 |
Rep 7,167
Drives: F90 M5 / F15 50i
Or someone's messing with you
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
08-15-2017, 10:48 PM | #8 |
Rep 251
Issue resolved by resetting the profile.
UPDATE: spoke too soon, the button programming is gone again will have to make an appointment to have this looked at. Last edited by ramsal; 08-16-2017 at 12:45 PM.. |
09-16-2017, 05:24 PM | #10 |
Rep 251
An update on my lost programming. Over the last few weeks I have tried everything to figure out what may be causing all of my programming to be lost with either key.
Well, yesterday I finally figured it out and I would be interested to hear if anyone else can reproduce this behaviour. It turns out that all of the programming is fine and is retained as long as you don't try to program a shortcut to "Diesel" gas stations, in my case. This is my first ever diesel and given that not every station carries diesel I decided to program one of my buttons to quickly pull up a list of nearby stations with Diesel. You can do this by: 1. select Points of Interest 2. select Fuel Stations 3. select "change location and filter criteria" at the top of the screen 4. select "Fuel Type" then the appropriate fuel and select "Set more filters" 5. change focus to "Show Results" and hold down the programmable button of choice to create the shortcut If I follow the steps above every thing appears to be fine until I leave the vehicle (locked or unlocked) for a few minutes and when I come back all of the programming is gone, on all 8 buttons. Looks like a software bug to me but I wouldn't mind getting someone to try to replicate it. I would really like to be able to program this so I can easily find a station when i'm on a road trip. Thanks
2018 M3
2017 X5 35d xdrive Msport Sold: 2014 X5 35i xdrive Msport Last edited by ramsal; 09-16-2017 at 05:31 PM.. |
Plokmp17.50 |
