08-28-2017, 12:17 PM | #1 |
Rep 745
Cost of walnut shel intake port/valve cleaning??
46k miles on my '13 35i and it's due for it's next service at 50k. No known symptoms as yet, but I'm thinking about having the intake ports/valves cleaned then as a precautionary measure. What's the going rate for this service from dealers and independents? Calif. owners' response would be most helpful.
08-29-2017, 08:37 AM | #2 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
Regardless of location I see $350 for a guy in his home garage, $4-500 for Indy shops and $6-800 for dealer svc centers.
11-24-2017, 12:33 AM | #3 |
sportscars only
3300
Rep 3,219
What's everyone's view on walnut blasting? I've never had it done but am way up there in mileage. I don't think I have any real noticeable effects. Just wondering if it should be done and when and description of any improvement. TIA.
11-24-2017, 09:34 AM | #5 |
Rep 906
My personal experience...
If you have no symptoms, then nothing will be substantially better after getting it done. However, you will eventually get some rough idle or maybe an occasional misfire when you really get on it but for me that was way over 100k miles before I needed it done. So, you can do it now to keep it problem free for another 50k miles or just wait until it shows signs of running rough that plugs/coils/injectors don't resolve. |
11-24-2017, 01:27 PM | #6 |
sportscars only
3300
Rep 3,219
What's the worst-case scenario for not doing the walnut blasting at all...car stalls? I've maybe had 1 second of a small 'blip' in revs when idling seldomly...is that a symptom? Other than that, it still runs great.
11-24-2017, 03:21 PM | #8 |
sportscars only
3300
Rep 3,219
11-24-2017, 05:57 PM | #9 |
Rep 745
Well for a start, direct injection and the fact that there’s no “backwash” for the intake valves. All DI engines are vulnerable to this phenomenon. Some, like current generation Mazda Skyactiv fours, are better designed to alleviate the problem.
11-24-2017, 08:44 PM | #10 |
Rep 561
Well ... that the positive crankcase ventilation system is not well designed. When there was fuel in the intake, it helped wash the oil vapor through. Now with direct injection its really obvious how the PCV system doesn't cut the mustard (it just pumps it into the intake). This is why folks run catch cans, and with HP run a better PCV valve (like the RB Turbo). But that doesn't solve it (just improves). The N54 PCV system is much the topic of discussion on various forums (Google is your friend). RB Turbo probably has the best complete replacement system.
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport. |
impulsE8918.00 |
11-25-2017, 02:26 AM | #12 |
sportscars only
3300
Rep 3,219
That's another consideration. I assume that dealers don't do it so ppl have to go to indies, which is kinda scary if something major happens.
11-25-2017, 07:35 AM | #13 |
Rep 906
My dealer will do it. You just have to ask for it.
They don't suggest it only because to inexperienced people it sounds like a bullsh$t service that the dealer is just trying to make money |
11-25-2017, 08:55 AM | #15 | |
Rep 906
You certainly don't want to fill the cylinder with the Walnut shells but there is a reason this abrasive is Walnut shells and not glass/sand. |
impulsE8918.00 |
11-25-2017, 08:58 AM | #16 |
Rep 561
The reason they use walnut husks is because it won't damage the internals, but it hard enough to remove the carbon deposits.
Think about it ... how do you blast something into the intake running and not have it go into the combustion chamber? Unless you pull the cams out, some of the valves are open. The walnut bits just blow out / burn up. Perfectly safe. Any good BMW independent shop can do this job, if they have the equipment. And if they have the equipment they've done it countless times because all these direct injection BMW's with crappy CCV's eventually need it. Like riding a motorcycle, not a question of if one will crash, just a question of when. Filippo
impulsE8918.00 |
11-25-2017, 09:11 AM | #17 |
Rep 906
Both valves in a port are perfectly closed when cleaning it. You can even spray in some solvent and it will sit there in a puddle.
The shell media will not get into the chamber except for the occasional grain just from the process. |
impulsE8918.00 |
11-25-2017, 09:31 AM | #18 |
Rep 906
Here is a pic of my first time doing this. I wasn't sure of how much of a mess I would make. Like the vacuum hose popping off or something so I really covered everything up.
by my third time I barely bothered to cover anything. Some pics of the required equipment It does take a pretty good air compressor to do this. If you already have one then getting the things you need to do this service is pretty easy. Last edited by NoQuarter; 11-25-2017 at 09:40 AM.. |
11-26-2017, 02:57 PM | #20 |
Rep 178
Drives: Z4 3.5i MSport manual, 2020X3M
Doing it is a bit time consuming. Make sure you have a large air compressor. Learned that the hard way. You can watch videos online to see the process and it’s not super hard. But it’s a lot of labor. I think the quotes were low. Add a couple hundred to the high side is what I was quoted match what I found. It ran great afterwards
11-26-2017, 03:11 PM | #21 |
Rep 906
11-26-2017, 05:28 PM | #22 | |
Rep 561
Filippo
