09-03-2017, 11:58 PM | #1 |
Rep 615
Car not hitting target boost
After successfully completing a manual swap this weekend, i went ahead and installed the 2-Step rev limiter and no lift shit. When i go to start the car, everything runs fine, so i check my jb4 for codes and it says i have a Faulty low fuel pressure sensor (29f3). I then disabled the jb4 and went back to stock tune and still got the code. JB4 and Backend flash worked before the swap. Im just thinking if the 2 step has anything to do with the fuel sensor at all. BTW 2-step doesnt work :/ even after trying to trouble shoot it using the install guide. Someone guide me through this please?
09-05-2017, 08:57 AM | #2 |
Rep 3,722
Man sorry to see you're still dealing with this. Did you test the car after the swap, but before installing the 2step?
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
09-05-2017, 10:05 AM | #3 |
Rep 615
09-05-2017, 11:03 AM | #4 |
Rep 3,722
Yeah I'd try that first and make sure it's not something else. If the issue stops with the 2step out then you know where your problem lies.
09-05-2017, 12:06 PM | #5 |
Rep 615
Yep. Hopefully that fixes it.
