11-06-2017, 08:35 PM | #1 |
Rep 5
Questions on tune/reliability for the n55
Hi,
First post. 1) Is dinan stage 2 the best bang for buck tune? Are there other chips/tunes I should look into? 2) Don't need to buy anything else for the stage 2 tune? 3) How much should I be expecting to pay in maintenance with this car a year? I DD a 2015 mustang GT and work from home. This will mainly be a rain/snow car. My mustang gets about 8000km a year. So this might just be 4000km a year. 4) Anyone know the 0-60 x1 35i with stage 2 tune? I couldn't find anything with the search function. Stock is 5.1. 5) What are the main issues to look out for with this car when shopping around? 6) Should I try and get a warranty from a dealer? |
11-07-2017, 08:43 PM | #2 |
Rep 2,404
Dinan would be the absolute worst bang for the buck. Completely opposite. Where did you hear that? Extremely high price, lowest power output.
On just a tune, or a DP/intake/tune, there are no reliability issues with the N55. It's completely solid even on larger turbos. A JB4 is arguably your best bang for the buck. That being said, but for the need to bench flash the DME first, an MHD/Wedge tuning flash (can be done via an android phone/MHD app) would be the biggest bang for your buck. Typically, a "stage 2" tune would at least recommend a downpipe. Pretty easy install on these cars. On a good day, an OTS tune and a downpipe could see you trapping around 110 in the 1/4. 0-60 are pretty meaningless measure, but you'd certainly be into the higher 4s.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
iwantanx14.00 |
12-06-2017, 06:05 PM | #3 | |
Chuggin' Along
333
Rep 588
12-06-2017, 07:14 PM | #4 |
Rep 443
Drives: 2021 X3 M40i (times 2)
Dinan or MHD if I'm not mistaken. Pure has something, but I don't know anything about it. JB4, VSRF Chargepipe and going to install a VSRF DP in the future.
12-06-2017, 07:33 PM | #5 | |
Chuggin' Along
333
Rep 588
Dinan sells their hardware with different piggybacks, not a true tune, at least for the n55. I guess a lot of this depends on the motor and year of the X1. I need to do some more homework. |
12-07-2017, 05:02 PM | #6 |
Rep 443
MHD is a flash for unlocked DME's. I don't know much about it, just that it is an option that some people prefer to JB4.
http://e84.xbimmers.com/forums/showthread.php?t=1438939 I wasn't sure if Pure did tuning, I threw out what I know for the OP to look into and others to chime in. |
12-07-2017, 11:09 PM | #7 | |
Rep 277
12-08-2017, 02:05 PM | #8 |
Rep 1,210
If you want more of a set it and forget it tune I would look at a flash option. MHD is what I would recommend. Yes, it does require you to remove the DME but it isn't that difficult of a job for you or a shop. People have already documented what you have to do. Pure primarily promotes the JB4 as does Fuel-IT. I am running Pure's stage 2 with MHD only on my N55 335i and love it.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
12-09-2017, 12:22 PM | #9 |
Rep 2,404
I see you posting about tuning your M2. You'll have all the same options, or perhaps more. While posting on the X1 forum would be encouraged, the bottom line is, the car is all E90 xdrive. So you'll get much more info on the more active N55 E series forums.
12-26-2017, 02:10 PM | #11 |
Rep 1,210
Stock boost levels are about 7 psi, PPK is a little higher. I think I have heard about 10 or 11 psi. Most stage 1 tunes are about 12 psi. PPK will have more power than stock but less power than any aftermarket tuning option.
12-26-2017, 02:23 PM | #12 |
Rep 37
I know some were able to flash the PPK software themselves on earlier model ECUs and it was pretty much a free tune. The later ECUs were locked and now require an activation code from BMW after the PPK flash. As far as I know the only way to obtain the code is to pay BMW. Either way the PPK was interesting to me because it was developed by BMW and didnt require removing the ECU. Thanks for the info.
01-20-2018, 05:07 AM | #13 |
Rep 5
Is maintenance expensive for these cars? Would probably be driven like 4-5k kms a year. Not tracking ir or anything harsh. Is the n55 or any other expensive parts (suspension..etc) of these cars prone to failure and I should expect some expensive repairs?
01-20-2018, 10:18 AM | #14 | |
Chuggin' Along
333
Rep 588
All BMW maintenance is relatively expensive though. |
01-20-2018, 11:21 AM | #15 |
Rep 1,343
Moot point since X1 doesn't come in n54 form.
Reliability is tough to say. Depends on previous owner treatment. General maintenance cost is higher. For example replacement of the AGM battery requires ecu reset which can cause 500-700. I've read quoted prices.... Tranny oil and filter change ~700 Diff oil ~ 300 Xfer case~ 400 Plugs ~ 500 That's assuming you can get the dealership to perform these tasks. Go indie or diy to save money. |
01-21-2018, 02:16 PM | #16 |
Rep 1,210
The oil housing gasket is prone to leaks, the coolant expansion tank is known to crack along the seam, oil pan gasket is known to leak, the plastic charge pipe is known to blow up even at stock boost levels, water pump failures are common around 96,000 kms, and the serpentine belt is known to be eaten by the crank pulley if it breaks, most people replace around 100,000 kms.
01-21-2018, 05:30 PM | #17 | ||
Rep 2,404
Water pump, oil filter housing gasket, oil pan gasket, etc. all occur on stock cars or modified cars, with all types of owners seemingly for no reason. It's not like these cars throw rods of break transmissions which one could pin on hard use. To the contrary, they withstand abuse well. Anything that may fail isn't going to have anything to do with treatment or the car, with or preventative maintenance. Quote:
$500 for $60 in plugs and an hour in the driveway? That's robbery.
01-22-2018, 04:50 AM | #18 |
Rep 5
Are there any years to avoid? I know often there are problems in the first year of production that they fix in the next.
And can you buy warranty for used cars? Any ballpark figure for how much that would be for this car? (Canada) |
01-22-2018, 09:50 AM | #19 | |
Rep 137
01-22-2018, 02:15 PM | #20 | |
Rep 1,343
In Canada, we got the 2012 pre-LCI X1. I'd avoid that because it's not as nice. If you follow the n20 timing chain issue, I believe BMW changed the plastic guide in 2015. You'd have to check the VIN to correspond to the date mfg. I think for the most part the X1 is quite reliable. It's not a complex vehicle in BMW's stable. CR rates 2014+ to be better. |
01-22-2018, 03:25 PM | #21 | |
Rep 33
The one video I found on youtube is for a 535i and its underneath the intake manifold. Is it a similar process on this car? I thought it was located in the control box in the upper left corner. The downtime of sending in the DME wouldn't be a big deal since I have another vehicle. |
01-22-2018, 03:54 PM | #22 |
44
Rep 209
DME is under intake manifold and needs to be removed for unlocking and open it up for future MHD flashing through the OBD port.
You will be down for 2 days or so when sending it out for unlock... rental car may be best bet...
X1 35i M-Sport, Pure Stage 2 turbo w/ inlet and outlet, 7in intercooler, Fuel-It PI and pump, Jb4 w/MHD, XHP, custom catless exhaust, KW V1, Volk's and everything else...!
