11-11-2017, 07:21 AM | #1 |
Rep 1,913
Drives: Here and There
Inconsistent Idle
Hello all.
I've noticed on a handful of occasions where my car will dip down in RPMs when I'm sitting at a red light. The car drives fine with no abnormalities, but every once in a while after coming to a stop, it will drop to 500 and maybe a little less and then it will bounce back up to about 800 and continue this pattern until I drive off. I have even had it drop low enough where it stalled the car once. Again, this is inconsistent and random when this will happen. Just got done driving 20 miles @ 80 mph on the highway? Sometimes it will dip at the light, sometimes it is a flat and level 800 RPM. Little hard driving in the mountains? Who knows what it will do! It is infrequent as well. It doesn't really seem like it's much of an issue with no codes or lights showing up, but it is odd. My big concern is any additional load it is putting on the engine at these low revolution speeds. I changed out my plugs trying to give that a go, but the results are the same. Has anyone seen this before? Not sure if these are MAF cars, but is it possible something like that is dirty? 2011.75 E90 M3 6MT Thanks! Tyler |
11-11-2017, 07:59 AM | #3 |
Rep 228
As stated above, idle control valve is the likely culprit as per research on this forum. I have seen this issue in my car a few times, but only when filling up at random gas stations while traveling. It hasn't happened since I have mostly stuck with the two or three BP stations in my neighborhood.
11-11-2017, 09:42 PM | #4 |
Rep 170
Hey mate,
No MAF on these, MAP only. Pull any stored codes and freeze frames first and see if you have any hints there but it certainly sound like the beginning of the end for the ICV unfortunately. Not uncommon on these cars. I have heard of some guys pulling the ICV and giving them a clean out with upper engine cleaner or similar with some success but if it's the PCB it's time for a new one. Pretty easy DIY, may as well do the throttle valve actuators whilst you under there as they WILL break Hope this helps, Craig |
11-12-2017, 03:23 PM | #5 | |
Rep 1,913
Thanks for everyone's input. Looks like I'll have to give the idle control valve a look-see. Is this an easy inspection/change out?
11-12-2017, 05:18 PM | #7 | |
Rep 170
It isn't a mech job, definitely a DIY if you've spun spanners before. You need to take the airbox out, plenum off, disconnect the TVA's, Vanos etc plugs, then you have access to it. If you get to that point I would change out the TVA's with some from Jason at Rebuild.org.uk, saves you doing them later as they WILL break. Printed Circuit Board - More specifically the components burn out/die. At that point you are need to replace the whole unit. Hope this helps Craig |
11-14-2017, 11:47 PM | #8 | |
Rep 75
http://www.m3post.com/forums/showthread.php?t=1273927 |
HerbNRacer145.50 spazzyfry1234374.00 |
11-15-2017, 07:48 AM | #9 | |
Rep 1,913
I will say that after a fill up I drove around with no issues. Stopped at a store after some driving, came back out, and the service engine light came on. I ran the code and it had to do with evap (so either the secondary canister or the fuel cap is what I would point it at). I had probably 3/4 tank in the car when I dropped it off at my local shop for some work to be done and we cleared the code to see if it popped back up again. Drove the entirety of the tank with no issues. Filled up and drove around for a while. Same deal...parked the car after some driving with no lights, but came back out and the light came back on. Do you think that replacing the cap could possibly alleviate my idle issues as well? |
Lt1camaro185.00 |
11-16-2017, 11:34 AM | #10 |
Rep 448
I just had this happen to me after a service on Friday. Does your idle dip regardless of if your in P, N or gear? I have a 2012 DCT, so it's interesting to see this affects both manual and DCT cars. By chance, is your brake pedal soft/spongy at all? I'm trying to determine if this could be the idle control valve or brake booster losing vacuum. I haven't stalled yet because of this, but I know my car didn't do this prior to my service, which was just an oil change and battery replacement.
11-16-2017, 11:56 AM | #11 | |
Rep 1,913
11-16-2017, 01:13 PM | #12 |
Rep 448
It's very odd that this problem happens randomly. If I am remembering correctly, I thought the factory idle was 750 rpms or close to that. I have been seeing 500-550 rpms since last Friday.
11-16-2017, 02:24 PM | #13 | |
Chitty Chitty Bang Bang
146
Rep 230
+1 for TurboPR
2012 Alpine White ZCP e92, AG wheels with 12.5mm rear spacers, PS4S 255/35-275/35 (No rubbing), 2.5 OEM Exhaust mod
11-16-2017, 04:03 PM | #14 | |
Rep 1,913
If we're having to pop off the plenum off and all, might as well change out the throttle actuators and the idle control valve while we're at it. And this is why my '71 Honda CB is in a million pieces. "Well since I have this off, I might as well do this......" |
11-17-2017, 09:45 AM | #15 |
Rep 161
Drives: 2009 E92 M3 DCT AW
Mine does the exact same thing, wasnt sure if normal operation. I seem to notice it more when im at a stop light with my foot on the brake but if i lift off the brake and im still stationary the idle seems to go up to about 7-750. Intermittent issue for sure and no faults stored.
11-17-2017, 10:27 AM | #16 | |
Rep 1,913
Same here, no faults. |
11-22-2017, 07:57 AM | #17 |
Rep 1,913
Coming back to this. My last two (or was it three...?) tanks were exclusively Shell. No issues since.
11-22-2017, 08:04 AM | #18 |
Rep 161
Yea since its been a bit colder i havent noticed it (same gas).
Current: 09' E92 M3 DCT Alpine white / Black
Current: 13' F150 Fx4 -daily Past: 04' E55 AMG Fbo, 03' E46 M3 99' E36 M3, 92' 240 RB26 408whp rocketbunny 03' SVT Cobra 481whp, 89' Fox 5.0 lx notch |
11-23-2017, 03:26 PM | #19 |
146
Rep 230
12-23-2017, 07:52 AM | #20 |
Rep 4,010
What did you figure out Tyler? Fuel tank breather valve or idle control valve? I'm getting this once in a blue on the E93 but it will actually stall. It's very rare that it does not stall if it jumps. And it will typically bounce over 1,000 rpms and then drop to zero.
12-23-2017, 08:17 AM | #21 | |
Rep 1,913
This is going into diagnosis mode at my shop when I change over the rod bearings. Hopefully we get it fixed...cheaply |
12-23-2017, 08:23 AM | #22 |
Rep 4,010
I have the Blue Driver OBD which doesn't show any issues, I just picked up the Carly so I'm hoping that might get a little more in depth and tell me if anything is happening when it occurs. I do hope it's one of the two above mentioned items though.
