11-20-2017, 06:56 PM | #1 |
Rep 1,915
Wheel/Tire size
My X5 has the stock 19'' wheels and tires 255/50/19.
Would like to move to 21'' 10.5'' wheels up front and 21'' 11.5'' in rear, with 295/35/31 tires up front and 295/40/21 in rear. Do you know if this set up is too much, especially on the front where even the X5M model uses 21'' 10 wheels and 285/35/21 tires up front? Will have to think about snow too, so I don't want a very narrow "gap" in the front. What worries me most is the 10.5" up front. Has anybody moved beyond stock specs on either F15 or F85? |
11-20-2017, 11:39 PM | #4 | |
Rep 826
Drives: 2017 C43 AMG
285/35/21 325/30/21 I just put new wheels on my car and went with those sizes. don't remember exactly how wide my wheels are but I think I'm running 10.5 and 11.5 or 10 and 11.5
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
11-21-2017, 12:22 AM | #5 | |||
Rep 2,388
[/QUOTE] Not me personally. I think stock staggered setup is good enough, but here you go with 315's all around: http://www.bmwblog.com/2015/10/09/bm...00-horsepower/ or this http://www.automobilesreview.com/aut...-f85-2/115566/ there's plenty of mods like that from different tuning shops, but those 23 rims are 11'' wide and they fit - so I think your 10.5'' rim should be fine No issues with XDrive if you are keeping overall rolling diameter/circumference same (or delta within 1%) The reason X5M uses 325/30/21? The only reason is to put down all that power X5M has and to keep rolling delta close to zero - there's no other reason |
11-21-2017, 05:45 AM | #6 | |
Rep 1,915
Wheel widths are 10 front, 11 rear. But I found a very nice looking wheel set to put my preferred tires on them |
11-21-2017, 05:53 AM | #7 | |
Rep 1,915
Not me personally. I think stock staggered setup is good enough, but here you go with 315's all around: http://www.bmwblog.com/2015/10/09/bm...00-horsepower/ or this http://www.automobilesreview.com/aut...-f85-2/115566/ there's plenty of mods like that from different tuning shops, but those 23 rims are 11'' wide and they fit - so I think your 10.5'' rim should be fine No issues with XDrive if you are keeping overall rolling diameter/circumference same (or delta within 1%) The reason X5M uses 325/30/21? The only reason is to put down all that power X5M has and to keep rolling delta close to zero - there's no other reason[/QUOTE] Thanks for the info.. Much appreciated! |
02-07-2020, 05:37 AM | #8 |
Rep 16
Hey Guys I have a BMW F16 with stock wheel of 19", I would like to get some bigger wheels such as 20 staggered or so on to make it look more aggressive, any advice. I heard it will be a problem for the xdrive is that true.
What would you guys recommend. wife is giving me this as a gift..🙂 much appreciate. Thanks
One day at a time..
02-07-2020, 08:44 AM | #10 | ||
Living the dream
4588
Rep 2,194
Drives: X5 w/MPPK, MPE & RC GTS Black
This^ Stick to a BMW OEM set and you'll be fine. There are many nice OEM options for our SAVs. poke around on here for the numerous wheel threads and you'll get all the info you need to make an informed decision.
Blekp16.00 |
02-07-2020, 11:10 AM | #11 | |
Rep 290
Drives: 2020 M4
Garage List 2020 BMW / F82 [0.00]
2016 BMW X5 35i [0.00] 2012 Porsche 991 C2S [0.00] 2013 Audi S8 [0.00] 2004 Ferrari Challe ... [0.00] |
20 by 11 on the rear. The big question then becomes offset. How close to the fender lip do you want the tires.... Personally, I like to stay close to stock offsets. You can always use a spacer to move the tire/wheel out, but you can't go the other way without machining the wheel. For tires I'd go 275/40 in the front and 315/35 in the rear. There are a number of very nice choices out there. As for the xdrive..... BMW supplies these cars with the tire/wheel combination suggested so I'm thinking you'll be ok. Last edited by andrewmr; 02-07-2020 at 11:15 AM.. |
Blekp16.00 |
02-07-2020, 11:19 AM | #12 | ||
Rep 16
One day at a time..
02-07-2020, 12:30 PM | #13 | |
Rep 33
02-10-2020, 03:33 PM | #14 | ||
Rep 33
05-10-2020, 07:48 PM | #15 | ||||||
Rep 35
thinking about this option what do you think. Square Setup 21x10.5 35 offset, tires...285/40/21 You think I will have any issues with this? Also 15mm rear spacer... |
05-10-2020, 07:50 PM | #16 | |||||
Rep 35
05-10-2020, 08:20 PM | #17 | ||||||
Rep 1,915
None whatsoever sir. Used Yokohama Bluearth over the winter and they worked perfectly... Style and grip! |
05-10-2020, 08:32 PM | #18 |
Rep 275
Love some more pics of the setup. Shot of the side of the car showing the stance wheels. What did the wheels run you cost wise?
11-11-2020, 12:21 AM | #20 |
Rep 3
Hi,
I've been searching a while, and haven't seen anything on this, but has anyone tried the Michelin Weatherready's in 255/50/19? I live in Southern California, but have a house in the mountains where it can snow a lot, so need something that's good for regular sunny socal weather and decent in snow conditions. The Weatherready's seem to rate really well on tirerack. Anyone have any experience? |
12-30-2020, 02:17 PM | #21 |
Rep 5
Need Help - New Used Wheels
I recently bought used wheels for '17 x5 50i xdrive. Sizes are 20x9.5 ET40 (front) and 20x10.5 ET35 (rear). Can I use this or was this a bad purchase? Don't want to mess the car up...thank you all in advance!
Happy New Years everyone! |
12-30-2020, 02:21 PM | #22 |
Rep 290
Drives: 2020 M4
Welcome to the forum....
Do you know what size wheels are on the car currently? Width and offsets? Are you asking about the wheels or tires as well? If so, what size tires? |
