11-22-2017, 11:05 PM | #1 |
Rep 42
2018 F82 - Valentine 1 Laser False Alarms
Just picked up a 2018 F 82. Moved existing fully updated V1 w/ savvy from prior 2014 435 into new M4. Unit is housed above my rear view at the top of the windshield via suction cup bracket. As soon as installed, constant laser alerts, ALL false alarms. No radar false alarm issues. Reached out to V1 and explained issue. V1 rep suggests that BMW updated the IDrive screen and that its the IDrive screen that’s causing the laser false alarms. When i asked for a fix, V1 rep suggested i tape a business card to the bottom of the unit to serve as a visor to prevent the V1 from seeing the IDrive screen below. Tried this today. Business card did not work. Going to try a piece of rubber and see if that works.
Anyone else having this issue? Any work around other than changing sweeps, getting a new detector (there’s nothing wrong w/ this unit) etc? Thanks |
11-22-2017, 11:26 PM | #2 |
BimmerPost Supporting Vendor
24477
Rep 191,448
Thats sucks, sorry OP.
Are they working on a software update to fix this issue?
11-24-2017, 01:12 PM | #4 |
Rep 81
I've not heard of this issue before. I have a V1 and it would false all the time on oncoming cars that trigger it but that's all. The reality is the laser detector on the V1 is completely useless. I've been nailed by laser and the V1 never went off. Over 99% of the time it's a false alarm, and the other 1% when you are being tagged by the cops it's too late. So your best bet is to simply turn it off. The only protection against laser is a good jammer like Anti Laser Priority.
The V1 is only good to detect Ka band - cops are rarely using X or K band. More and more are using laser. Your best bet is to get the YaV1 app for Android (hopefully you have an android phone) and learn how to set it up - it has GPS lockouts that learn where all the false X bands are etc etc. My V1 rarely goes off unless it's a true threat. I also have the ALP laser jammer, and use Waze all the time as well. You can set up your phone using Llama so that when you get in the car it automatically starts up all the apps one after the other without having to do it manually. It's pretty cool once you get it all working. |
11-25-2017, 12:34 PM | #6 |
Rep 40
I had the same issue with my 2018 M3. (No issues with my 2015 M3 using the same mounting location and detector.) The laser alert on my Passport X50 stayed on the whole time. It is mounted under the rearview mirror with a blend mount installation kit. I had to angle my detector slightly upward to get out of the field of view of the iDrive screen. It seems to be working.
2022 G80 Competition X-Drive
11-28-2017, 01:51 PM | #8 | |
Zymurgist
89
Rep 161
I'm with Howard and switched off V1 laser detection. I plan to install the ALPriority laser system within the next month or so (2 regular heads + TX head in kidney grilles). |
12-04-2017, 09:14 AM | #9 |
Christmas Poo
1174
Rep 1,239
Played around with my car today with an extension cord on my V1 and agree the source is not the iDrive display...there appears to be a laser diode beneath the front windshield camera pointing forward. Just under where the "connected drive logo" is located. Lights up the V1 every time its near it. I think this is creating some scatter within the windshield that the V1 picks up when mounted anywhere around the rear view mirror. The farther away mounted from the rearview mirror the fewer falsies. If I mount mine near the A-pillars there is no false laser picked up at all. Just not a convenient location for the visor to work well.
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
Powaup1259.00 |
12-05-2017, 09:44 PM | #10 |
Rep 31
I have a 2018 m3 and I’m having the same problem with my V1, so it’s switched off for now. Hopefully someone can source this problem very soon.
Subscribed |
12-06-2017, 11:17 AM | #11 |
Christmas Poo
1174
Rep 1,239
For now you can mount it over by your A-pillar, just get it away from the mirror/camera complex in the center. It will still reflect off cars in front of you though and give some false alarms. Otherwise there is no way around this unless radar detector manufacturers can come up with some type of filtering...
12-06-2017, 02:13 PM | #12 |
Christmas Poo
1174
Rep 1,239
Also you can just program off your laser band and leave X, K, and Ka bands on...
12-07-2017, 02:09 PM | #13 |
Rep 299
Drives: m3 2015
I was at a track day Monday at Robbling Road in Savannah Ga and several V1 users had that problem. Never had that type of problem with my K40
12-08-2017, 10:00 AM | #15 | |
Christmas Poo
1174
Rep 1,239
Going to look into a Uniden R3 as it appears much narrower than a V1 and will be easier to mount over the left side of the windshield. And if that doesn't work my wife will inherit a Uniden R3...V1 is MUCH quieter over there but can't fold down sunvisor. First world problems...
12-08-2017, 10:10 AM | #16 | ||
Plenipotentiary
2614
Rep 3,046
On F8x, the only component with LIDAR (identical to a Laser Speed Gun) is the ID6 Touchscreen introduced for MY18. If you want to test this, take black electrical tape and mask off the outer 1/2" of the screen. |
12-08-2017, 10:16 AM | #17 | |
Christmas Poo
1174
Rep 1,239
12-08-2017, 06:53 PM | #18 | |
Rep 2,286
12-08-2017, 09:11 PM | #19 |
Rep 3,157
Same issue . i sold my last one that was on my 2014 435 which started doing this after about 2 years. Bought a new one for my 2017 m3 and it worked fine for a few weeks then started doing it again. I ended up uninstalling it and putting it in a drawer.
12-13-2017, 07:58 AM | #21 |
Rep 119
had the same issue with the laser alarm on my 18 F82, I just coded out the laser sensor using the V1's manual. No issues, however no true laser protection now, however thats mostly just a "yep you are hosed" alarm anyways if you are truly speeding. ALSO, I have no driving assistance devices, just Idrive and HUD. My V1 is suction cup mounted to my windshield just to the left of the mirror.
12-16-2017, 04:29 AM | #22 |
Rep 4,203
My LCI M2 is doing the same thing....just took the set up from the '15 M4 and moved it to the M2 but I have deemed it unusable. I used an extension and moved it around the cabin and for sure it is not the i-drive. I feel it is coming from the rear view mirror pod area. If i could come up with a cool mount set up to put on the outer edges of the cabin somehow it would be fine but........
I didn't use it mac anyways My set up was blend mount, dual wiretap running V1 and Mobis dash cam both auto on |
