12-12-2017, 03:02 PM | #1 |
Sideways and Smiling
3029
Rep 2,860
Drives: In Exuberance
CV/Half Shaft Failure?
I've had a noise coming from the rear, passenger side of my car, as some may be aware. It has the sound of a wheel bearing, but the bearing has absolutely no play in it. Under a stethoscope, the bearing makes very little noise, but that noise sounds like a normal, healthy bearing.
Today, I was again browsing around the rear subframe area, and found that my half shafts have some play in them. The passenger side one moves towards and away from the diff pretty easily. The driver side one doesn't move easily, and when you can move, you can only move it very minimally. Is this an indication as to the health of the half shafts? Which one is in worse condition? Any help is greatly appreciated. I want this noise gone. If not this year, next year. Thanks again!
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
12-12-2017, 03:20 PM | #2 | |
Rep 6,196
12-12-2017, 05:14 PM | #3 | |
3029
Rep 2,860
Any ideas on the half shafts?
12-12-2017, 05:18 PM | #4 |
Rep 264
Rear bearing failure is pretty common on the e80x/e90x... rear axles not so much.
Not sure I would put the car in drive on jack-stands, that would be pretty unsafe.... best bet is to get the car on a lift. |
12-12-2017, 06:19 PM | #5 |
3029
Rep 2,860
It seems that the CV joints aren't supposed to have as much play as they do. While I'm replacing the wheel bearing in the near future, I'll also be replacing the axle. I'd rather have to only take everything apart once per side, than to find out I replaced the wrong thing, and have to take it apart again.
12-12-2017, 09:29 PM | #7 |
3029
Rep 2,860
Yes. Clutch disengaged in gear, or clutch engaged in neutral. It makes the most noise under medium/heavy acceleration, or in any form of cornering.
12-13-2017, 08:19 AM | #8 | |
Rep 6,196
