12-14-2017, 02:56 PM | #1 |
Rep 184
Brembo Problems, please help
So i just had some Brembos installed on all 4 corners and now my brake pedal has a ton of travel in it compared to the stock set up. The shop that did the install said it was do to the different amount of pistons and the piston sizes from the stock set up.
Does anyone else with Brembos have this problem? Can this be fixed??? Appreciate the help
2016 X5M
JB4, DME Tune, Full Custom Fab Worx Exhaust w/ Straight Pipes and Cutouts, KW V3, 22" BC Forged Wheels, Brembo BBK on all 4 corners |
12-14-2017, 03:38 PM | #2 | |
Rep 184
12-14-2017, 04:01 PM | #3 |
Rep 242
I'd also make sure they bled your brakes and there's no air in the system
Edwin
2017 CB X5m
MisterJudyMoncada63.50 |
12-14-2017, 04:14 PM | #4 |
Rep 644
You need to have the brakes fully bled again to ensure there is no air in the lines. Like the others have said, almost guarantee this is the problem.
Has nothing to do with more pistons or what not. Feel should be exactly the same if not better if they did it correctly.
2017 X5M, Donnington Grey, Aragon Brown
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3 21" Vossen VFS-1 on Michelin PSS |
MisterJudyMoncada63.50 Travis1807108.50 |
12-14-2017, 05:07 PM | #5 | |
Rep 242
Edwin
2017 CB X5m
12-14-2017, 05:09 PM | #7 | |
Rep 242
Is this a performance shop that did the install? Edwin
2017 CB X5m
12-14-2017, 05:35 PM | #8 | |
Rep 184
and yes it was done by a very reputable speed shop.
2016 X5M
12-14-2017, 05:40 PM | #9 | |
Rep 242
Edwin
2017 CB X5m
12-14-2017, 06:08 PM | #10 |
Rep 644
Exactly... You have a safety issue, the only place I'd drive it is straight to get it fixed.
It is possible to have the brake fluid reservoir look full but still have air in your lines. If I remember correctly, this usually happens when they are bleeding, don't keep the bleeder tank filled enough with fluid, and suck air in when it runs dry (since the whole thing is under a vacuum state). Then, they top it off to make it look normal without knowing it happened. You can usually tell because you get a very audible sucking noise when the bleeder tank goes empty. You pedal should be rock solid and even more touchy since you got a BBK vs stock. Even reputable speed shops make mistakes. |
12-14-2017, 07:55 PM | #11 | |
Rep 184
Appreciate the info.
2016 X5M
12-14-2017, 10:04 PM | #13 |
Rep 4,532
Take this comment with a grain of salt as I’m not 100% sure..,.,,,could also need a program update. Some of the X5 guys had to do some updates when going to larger brakes.
12-14-2017, 11:32 PM | #14 |
Rep 18,794
Sounds like improper installation and sounds like that shop doesn't know how BBK works.
Make sure the calipers are installed in the correct position, rotors are in the correct direction, bled in the correct way, and bed the brakes afterward.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
12-15-2017, 09:54 AM | #15 |
Rep 901
Hey guys, aren't the stock breaks on X5M and X6M already Brembo's?
Sold: 2020 X7 M50 White Mineral with Ivory & Blue, 2017 X6M Long Beach Blue with Mugello Red, 2014 X6M Monte Carlo Blue with Mugello Red, 2011 X6 5.0 Black on Black, 2008 E350 4Matic Silver, 2006 Infiniti M45 Diamond Graphite
12-15-2017, 10:18 AM | #16 |
Self-Deprecating Narcissist
7274
Rep 6,561
yes. they are 6 piston brembo caliper / brake system. i am not sure what the OP installed or why but if you have a plain jane X5 and upgraded to the MPBK or a brembo kit then you need to code the brake system into acknowledging the system and compensating for the new calipers at the booster.
12-15-2017, 10:58 AM | #17 |
Rep 184
12-15-2017, 01:08 PM | #18 |
7274
Rep 6,561
12-15-2017, 06:49 PM | #19 | ||
Rep 644
OEM is six piston front, single piston rear. I personally don't like the rears, you'd think at better styled caliper would come with a $100k+ SAV. That's what makes the Brembo mod the gents in Russia are doing so intriguing...
12-15-2017, 08:04 PM | #20 |
Rep 209
The last time I installed a BBK on a car was 15 years ago. It would appear that times have changed... you seriously have to 'code' the system? What exactly does this do? Are the X5M brakes not hydraulically assisted via direct link from the brake pedal or are you saying that they are brake by wire with no physical connection between the pedal and cylinder and an electronic link that can therefore be altered? How do you 'code' for different aftermarket systems if BBKs does not come with proprietary programs for uploading into the car?
12-15-2017, 08:06 PM | #21 |
Rep 209
12-15-2017, 10:17 PM | #22 | |
7274
Rep 6,561
http://www.bimmerfest.com/forums/sho...9&postcount=26
