12-15-2017, 07:45 PM | #1 |
Rep 11,891
Any M6 or M6 GC owners actually performed the exhaust valve mod?
I need tips on how to access the controller solenoid.
I adjusted my tips today, and I saw that the solenoid for the flapper is way on the outer pipe and nestled against the corner of the bumper. I removed the outer tip and barely could put my hand up on it, let alone string a piece of wire and tie it. Almost seems like you need to unbolt the exhaust and let it hang down and do the mod, or remove the bumper. I looked at pics of the M5, and that car has way more room to work under the bumper than the GC. Like literally I had to take a second to find the solenoid bc it was hiding behind the bumper. Any tips? I approached this with the car flat on the ground and from behind. Do I actually need to be under the car and looking it downstream to access it? Btw I have the Akra MPE. But should be the same as OEM
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 12-15-2017 at 09:47 PM.. |
12-16-2017, 01:55 AM | #2 |
Rep 804
I went with Exhaust Meister. You plug it into the trunk behind the driver side carpet and then you can set up your mirror home link buttons to open/close the flaps. It comes with 2 remotes as well and I think it's around $120 or so.
kris1858572.50 |
12-16-2017, 12:15 PM | #3 |
Rep 110
I did this mod on my M6GC... it's definitely a tad louder on start up.... but the exhaust is still a bit "mild".... I am off the next two weeks and seriously considering building a muffler delete and install........
Flying Ace4992.00 |
12-16-2017, 02:00 PM | #4 |
Rep 11,891
I'm unsure if I want to do the mod now. As you said, it'll be the same sound you get at startup, just the entire time.
12-17-2017, 12:15 AM | #5 |
Rep 11,891
Got 'er done. Definitely had to get all the way under to perform the work
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
12-17-2017, 10:48 AM | #6 |
Rep 126
Agree with Malcoll. My M6 is bog standard, apart from the exhaust valve mod. Marginally more sound on cold startup, but not really much difference once running. I've also disconnected the ASD unit, so now I can hear the REAL sound! Much better...
12-18-2017, 05:58 PM | #7 |
Rep 3,071
I did this with car on ground. Use a long screwdriver to push valve open, I used top plastic tie straps to hold open. A little louder at idle and start-up, but not loud on the go
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
12-18-2017, 07:40 PM | #8 |
Rep 11,891
I haven't driven the car with the mod yet. If not real difference, then I'll probably just revert it back.
12-21-2017, 05:11 AM | #9 | |
Rep 425
Seeing as it's a very cheap and simple mod it's definitely worthwhile doing to see if you like it. Easy enough to change back. |
12-21-2017, 09:52 PM | #10 |
Rep 419
Drives: '23 BMW M8 Competition
Same here... However to get the most out of the cold start, just replace your OEM downpipes with high flow non-catted downpipes.
CF mods from Manhart, 3D Design, Dinan, Vorsteiner and IND. Custom CF steering wheel, Custom ADV.1 510 M.V2 Advanced Series 21inch rims + titanium hardware. Carbahn Tune – 771 HP 738 lb-ft Torque, Manhart CF Intakes, Dinan CF Turbo Inlets, Keller Performance Titanium Cerakote Race Midpipes, KW Height Adjustable Spring (HAS) Kit.
12-21-2017, 10:05 PM | #11 |
Rep 11,891
Next time I'm under the car, I'm going to reve this mod.
12-22-2017, 06:28 PM | #12 |
Adam
124
Rep 269
Drives: Lusso, GT3, 360, Vaquish, bike
Garage List 2021 Jeep Gladiator [0.50]
2004 Ferrari 360 Sp ... [0.00] 2014 Aston Martin V ... [0.00] 2014 Porsche 911 GT3 [10.00] 2017 Ferrari GTC4 L ... [10.00] |
Flying Ace, not seeing much of a difference ?
I also did the exhaustmeister and love it. |
markymarc1979272.00 |
12-22-2017, 08:03 PM | #13 |
Rep 2,534
Drives: 16 G12 + 15 F06 + 17 F15
Love those tips. Pure sex. Any chance you know the inlet and outlet size of those?
12-22-2017, 08:41 PM | #14 |
Rep 11,891
Sorry, I don't have those CF tips. Someone else said the Akra is a 67mm inlet. I cannot confirm.
12-24-2017, 05:52 AM | #15 |
Rep 51
Did the valve mod on my stock exhaust but I do a lot of 5 hour motorway journeys and the extra noise got on my nerves by the 3rd hour so put it back to stock
12-24-2017, 10:16 AM | #16 |
Rep 110
Did you deactivate the ASD? Before doing that the drone was almost unbearable, with ASD off, I like it and actually am considering the Muffler Delete......
12-24-2017, 10:28 AM | #17 |
Rep 51
No I didn't and at motorway speeds the drone was driving me crazy. If it was the ASD "enhancing" the noise I'll give disabling that a try as I definitely prefer the sound of the car with the valve mod.
12-24-2017, 11:03 AM | #18 | |
Rep 11,891
