01-07-2018, 02:37 PM | #1 |
Rep 3,071
Check Engine Light On here are the codes
Carly:
Mixture control, bank over cross: mixture too lean Code: 118010 Mixture Control: mixture too lean, large deviation Code: 118401 OBD2 Reader shows 3 faults P0174 and P0171 System Too Lean My battery is now constantly asking for charging, could this be related??
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
01-07-2018, 02:47 PM | #2 |
Rep 632
Drives: 2014 M6 Grand Coupe CP
these codes are indication of air leaks downstream (after) of the mass air flow metering. Usually either small vacuum hoses or in older cars cracks in the rubber sections of the intake.
Try spraying some "starter fluid in those areas and see if the RPM changes. That indicates where the leaks are. good luck
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
01-08-2018, 10:57 AM | #3 |
Rep 3,071
Going to dealer for new battery and check on codes. Could be due to low voltage causing code.
01-11-2018, 05:53 PM | #4 |
Rep 3,071
Dealer called and told me that they are going to replace the valve covers. I wonder if its the cover or the gasket and one or both. I also wonder if this has anything to do with my excessive oil consumption.
10-11-2018, 01:30 AM | #5 |
Rep 330
Hi I'm having the same issue now on my M5 what was the issue? Did they fix it? Can u help me please I'm getting same 2 codes.
10-12-2018, 08:06 PM | #6 |
Rep 3,071
Heat is a major issue on these cars, code went away after new battery and gaskets...
Tags |
code, fault |
