01-22-2018, 01:49 PM | #1 |
Rep 188
Unable to show metadata when connected via Bluetooth
Hi,
most of the times i connect my phone via bluetooth, the player is unable to read the song name, artist, track, etc. also the back & skip don't work. it really doesn't matter what i'm using on my phone to play songs, Apple music, spotify, etc. it happens with all of them I have 2016M4 ID4. anyone got the same issue? solution? |
01-22-2018, 02:59 PM | #2 |
Rep 4,000
Same issue here.
I haven't found a permanent solution, but this works for me. 1. Start playing song via Bluetooth 2. Switch to radio input then back to Bluetooth
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale |
hanafimahmoud65.50 |
01-23-2018, 12:58 AM | #3 |
Rep 188
02-23-2018, 04:41 PM | #4 |
M3MBER
75
Rep 129
Drives: F80 M3 -Yas Marina/Silverstone
I loaded the latest free software update onto a 2GB USB stick and plugged it in to my center console USB. Took like 2 minutes. Metadata over bluetooth has worked flawlessly since then and also looks a lot cleaner. The update notes mention metadata but they did not go into much detail, but I assume this fixed the problem. Also I am not sure what the "Add-on" software does, but that was not on my system before the update.
Just put your last 7 of VIN and it will take you to the correct download. FYI this was done on my 2015 M3 https://www.bmw.com/en/footer/software-updates.html Before- Media version: MN-002.052.001 Telephone version: TN-002.052.001 After- Add-on version: HN-002.255.073 Media version: MN-002.255.071 Telephone version: TN-002.255.070 The following adjustments are made during the software update: Multimedia ▷ Activates audio output when the Tagesschau app is used. (independent of device) ▷ Improves the display of long track names. (independent of device) ▷ Corrects playback of podcasts. (Apple devices with iOS Version 8 and higher) ▷ Clears the display of old metadata after a change of track. (independent of device) ▷ Removes superfluous note on app installation. (Apple iPhone) Phone ▷ Enables the use of BlackBerry devices from OS 10.3 for data services via the mobile telephone. ▷ Allows closing of individual reminder messages. (independent of device) ▷ Improves filter function for e-mails and text messages with BlackBerry mobile telephones. (BlackBerry: Torch 9800, Bold 9900 with OS 7.1) ▷ Improves the audio quality when using the handsfree system. (Apple, Motorola and Samsung mobile telephones) ▷ Improves downloading of messages from mobile telephones to the vehicle. (independent of device) ▷ Improves the reminder function for calendar and notes from mobile telephones. (independent of device) ▷ Improves synchronisation with mobile telephones. (independent of device, with the exception of some Nokia mobile telephones). ▷ Improves the transfer of call lists to the vehicle. (LG, Samsung and BlackBerry mobile telephones) ▷ Improves the display of Chinese names in Chinese vehicles. (Android mobile telephones) ▷ Improves the display of journeys made in the service Online Driver's Log. (independent of device) ▷ Improves display of the distance. Distance is given in kilometres and miles in the service Online Driver's Log. (independent of device) ▷ Improves the display of special characters in the ConnectedDrive portal. (independent of device)
2015///M3|Yas Marina Blue|Silverstone|
Encanto1171.50 |
02-25-2018, 03:01 PM | #5 | |
Rep 188
03-03-2018, 02:12 PM | #6 |
M3MBER
75
Rep 129
Disregard my post. My car has now been doing the exact same thing. I tried forgetting the device on my phone and removing it completely from idrive but it's still happening. Hopefully someone else has found a fix. Cuz it was working fine. And I haven't done any iOS updates on my phone, it's been on 11.1.2 since I got this phone and was working fine on it until now. Not sure what changed
03-24-2018, 07:01 PM | #7 |
M3MBER
75
Rep 129
Is your iphone jailbroken? I finally got to the root of why mine was doing this and it was a certain cydia tweak that I had installed. BatteryPercentX. I uninstalled it and it has been back to working ever since. If you are not jailbroken, then I am still stumped.
Tags |
id4, idrive |
