01-25-2018, 01:00 PM | #1 |
Rep 5
Motiv twin disc clutch/flywheel
This is a Motiv Motorsport twin disc clutch/flywheel setup by Spec. (edit) forgot to mention it is for the N54 motor/trans. It has the trans pin adapter as you can see in the picture. Pressure plate bolts are there too just not in the picture. (end edit) It is their previous generation PT model. New it was $1800+ This is a 6 bolt version. It only has a few hundred miles on it because the engine blew (unrelated to clutch) and was replaced with an 8 bolt crank engine. So this clutch/flywheel would not work. Was saving it for a future project but need to clean out the garage. I do NOT have the clutch alignment tool. This can easily be obtained from Spec. Will ship. Paypal or USD cash only Last edited by bgbracing; 01-25-2018 at 02:00 PM.. |
02-07-2018, 02:03 PM | #5 |
Rep 174
Trying to reach you, have payment ready. Just need to verify you can do the deal. Thanks.
2010 BMW 135i
Alpine White, Manual Trans, Navigation, Boston Leather N54Tuning Dowpipes MMP Inlets Eisenmann Race Exhaust with mid cat delete AMS Intercooler BMS Chargepipe with dual Forge BOV Ohlins Road and Track (Vorshlag camber plates) M3 control arms Rear Subframe Bushings OCC and RB PCV |
